  • Replies 127
Posted Images
First of all guys want to apologise for the poor quality of the photos - I was using my Iphone and it take rubbish photos so bear with them.
Update!!!
I have the engine and gear box out! Took it out the bottom with the cross member and gearbox attached. Nice part about it all - I have been able to clean everything. I was able to stand in the engine bay and prepsol the whole thing!!!
All I can say is - WHAT A BITCH OF A JOB! People complain about working on mini's because they're tight in the bay but by god this car brings it to a new level! The engine is now out and on a stand getting lots of work done, well almost lots. There is a new timing belt, new ilder bearing, water pump, plenum gaskits and exhaust manifold gaskets.
The amount of parts that have come out of the bay and off the engine are endless.
As you can see in the pics - I have pulled the turbos apart... I went to rebuild them using the kits I bought but the turbine wouldn't fit! Turns out I have NISMO N1 turbos on the car! I was wondering for people in the know - do all GTRs have an adjustable exhaust cam gear? looks standard... See pic:
Now onto the sump:
Are the sump baffles in?
Can this be done without hauling the motor out?
I kinda want to swap my sump for a bigger one, but cant be f**ked with engine out.
Well hate to tell you this - no you cant do the sump with the engine in the car. Well I cannot conceive of any way you could achieve this. These are the pics and a mini how to:
Take your sump off the bottom of the engine. Make sure you do it with the engine up the right way so no rubish or debri falls into the block.
Take out the standard baffle palte with the 10mm bolts. Block off the breather hose for the transfer case and get the sump into a parts washer. Wash it thoroughly. Dry it thoroughly.
Take it to a bench and drill a number of holes from the flat part of the sump back to the deep part of the sump. Make sure the edges of the holes are not burred and nothing in the future will break off and destroy your engine.
Take one very nicely made, yet unreasonably expensive, TOMEI sump bafle kit and bolt the bastard in.
Stand back and admire your handiwork. Bolt the sump back on!
The turbos are off being fettled at the moment. The aircon compressor is being overhauled and the gearbox has been cracked open and all the bearings and synchros looked shmick!
Just ordered the clutch from Kudos. Hope it comes soon as I will be needing it very shortly! Just bought a HD exedy item. I cannot see myself pushing the engine too much further in the near future so it will be good enough.
Thanks guys. I should get my my turbos back from Turbologic today, mmmmm lovely rebuilt NISMO turbos.... Clutch kit arrived which is nice as well! One more step closer! The a/c compressor winding are stuffed. GEtting them rebuilt as well! Going to be lovely and new soon!
Hopefully on Friday I will get some pics of the engine all painted and back together! Plenum went on yesterday along with the new heater hoses! Gearbox is all back together and will run like a top!
  • 1 month later...
We thought it would be a good idea to do the sump with the engine in - It is possible, but probably harder than pulling the whole engine to be honest!
Support the engine from above, take off sub-frame, pull gearbox apart from engine, take sump off and add baffle/extend, reverse. Not really as easy as it sounds :)
saw ya yesterday on hume h'way/m5, that was me in the gunmetal r32 gtr
have you put an ecu in your car yet mate??
Not yet... I am on the look out for a power fc atm. I had the car at unigroup on monday to check fuel ratios and make sure it was happy and safe. Makes 205rwkw on 8psi :D Loved the sound of yours! You live local?
That sounds like a complete pain in the ass. Why not pull the engine and do a major service when putting in the baffle?
Alrighty! I have finally uploaded some pics of the build...
The engine with the new covers painted and mounted back on the subrframe for installation!!!
Back of the engine with the new clutch installed!
Here is the lovely rebuilt NISMO turbos... We had to order new compressor wheels from NISMO japan for them...
More to come!
looks fantastic !!!!
engine looks sooo clean now lol will look soo good in ur engine bay
u mentioned you have lag? will be worth the money to put an adjustable cam gear on the intake side aswell (you already have an exhaust one right?) and get them tuned with the power fc :)
nah im from sutherland shire, was coming back from picton go-karts for a corporate event...
:D
:D
Ahaha, I was coming back from Picton seeing family as well!!! Dont see full boost until 4500rpm. I will get prob a matching pair of gears when I get a power fc...
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
