Hi all! I am trying to find nice 2nd hand wheel for my 4 stud friend...
any 4 stud 17" should be alright....
anyone have their wheels for sale?
Jeff ash if you are reding this, do you have and nice wheels at your place? I pop down to work shop but you wnarnt there but I did talk to Roy... he said talk to the man "Jash" :D
anyone know the 2nd wheel place around the perth, I tried majority of the tire places...
I hear there is 2nd hand wheel and tire place at KEWDALE anyone know their phone number or address?
much appriciated..
cheers
Joe
https://www.sau.com.au/forums/topic/3203-tires-and-wheels/
Dude,
4 Stud 17s are massively hard to find. I wish I had a buck for all the times I've been asked. I've got plenty of 16" sets about, but the only thing I've got in 17" 4 stud is a brand new set of 17x8 P1 Racing IIs which are about 7 fiddy each without tyres.
Jash
https://www.sau.com.au/forums/topic/3203-tires-and-wheels/#findComment-54841
That's is fine looking car if I may say so... I hope you looks the same... :D
well check your PM.
If you want to sell this week my offer is standing...can be negotiated I guess.
but that offer is even without looking.
I suppose to buy 17" wheel tomoro...
so let me know
cheers
Joe
https://www.sau.com.au/forums/topic/3203-tires-and-wheels/#findComment-55207
lauren-PM
I'll see you then...
cheers
Joe
ps. if I go missing tonight, the last person to see me would be you know who... if my skyline goes missing then you know who... man I am scary to make a trip to that woop woop...
I hear skyline drivers get hijacked and beat up...
I hope you are not psyco cuz I am not (even though manyh ppl disagree with me) LOL :D
https://www.sau.com.au/forums/topic/3203-tires-and-wheels/#findComment-55332
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
