Hey Peter, the S-Tune where not a factory car. The S-tune packages are basically you take your car to NISMO and they put on "S-Tune" spec extra's. Suspension, exhaust, brakes etc etc.
There is also an R-Tune option as well, where its just a little more hardocre.
So there's no numbers built as anyone can pop into NISMO and have the upgrades.
Thanks heaps mate i am looking at one at the moment, do you happen to know what other mods were available ie turbo,engine, ecu??
Nismo S-Tune Sports Resetting
Nismo engine tuning of ECU, maximise engine performance = sportier engine characteristics,
ECU
Air Intake Filter
Spark Plugs
All upgraded.
Nismo S-Tune S1 - Same as Sports Resetting but with,
N1 Twin Turbos
Dump Pipes
Head Gasket
Cam Shafts
Nismo R-Tune R1 - Same as S-Tune S1 but with,
Twin R1 Turbo's with larger Actuators.
- Piston (N1 spec)
- Piston Ring (N1 spec)
- Exhaust (N1 specification) a camshaft only · R1
- Fyueruinjekuta (large type) · only R1 ECM
· Airflow ( large type) - Sport air filter
- Metal Gasket
- Main Bearing
- Con Rod Bearing
- Oil Pump
- Oil Pan Baffle
- Timing Belt
- Reshingupuragu
(What ever I can work out from the pic) :P
Nismo F-Sport GT Same as R-Tune R1 but with,
2.8lt Stroker kit.
Nismo Z-Tune
Total rebuilt from ground up at the Nismo Omori Factory.
  • Like 1
I have been doing a bit of research on the different r34’s around and have heard about a Gtt s-tune just wondering if any one out there knows much about them ie what options, mods they came with, how many were built etc?? Cheers peter
[/quote=jrockz datr 26 may 2010]
Hey mate today i saw r34 gtst s tune.it was built 1999 and it got loward suspention and nismo catbak exaust.looks great.cheers
