nah I always leave it till the pump is primed. I hear it Click off in the boot (noise courtesy of the big bosch pump :)) but it still is hard to start. most times have to touch the pedal. esepecially when its cold.
also clutch is really loud till you hold your foot in on the pedal.
When is the last time you got your injectors cleaned and flow testered?
  • Replies 121
i have a relay in the boot that keeps clicking. i think its for the hicas pump. ive been told its a bad earth or something. any ideas anyone? does anyone know where the major earth points are for the wiring system?
4. still cant get to blow air up on the front windscreen with the AC off.
I think this is normal? Mine does it too? Its annoying when its cold and you have to have cold air blowing in to demist the screen
  • 2 months later...
I think the wiring in my car is loopy, i believe it thinks the boot is always open (int light on and boot light on, i had to remove), and the alarm believes this too. normallly that is ok, alarm ignores that one trigger point, but yesterday alarm started going off for no reason, and keeps doing it. had to turn stupdi siren off...
Anyone have ideas about wiring & how to fix? This is actually REALLY annoying me....
i've got a whining noise coming from my steering column... but the dirty sanchez dosen't make the noise when i take it to the mechanic, but it starts up again the moment I get home. I've made around 10 trips to mechainics, only to have em look at me n go "what noise?".
My car is a dubious manipulator. The voices in my head agree with this too.
No really I have a whining noise which comes on and off. it increases in pitch when the car is moving faster. The faster my wheels are turning the higher the pitch. Its inaudible from the outside and while inside it seems like its coming from the steering wheel.
One of these days I'll gut the car to find a worn out bearing causing it and I will rage out on that bearing making the rest of its life a living hell.
this makes me feel good about my car, nothings really wrong with it like this, 1 or 2 rattles i've still gotta find , got rid of about 3 already...
sometimes i have to look out the left hand window to see where i'm going when i go around a corner on boost.... i think thats my tyres tho :D
i have to have the air con on to get the air on the windscreen too.
Yup... my aircon automatically switches on if I just press the demister front or rear.
The freaky stuff my car does atm is below:
-> when cold the break pads sqeeak... very bad.. ok after I drive the car and use the breaks a lil.
-> RATTLING! dammit I had rattling and I still havent even put in my sub yet. :D Thinking of taking out the trims and re-sit them backin and see if it will solve me rattling problem.
-> A flat spot? at ~2 or 3000rpm, tho I think it might be due to the triptronic gearbox or something.. not sure yet...
-> After the car warms up the idle is not constant.. (some misses) or when I park my car on an angle with the front higher than the rear.. Taking this back to the mechanic workshop soon to work out why..
-> Tendency to attract lots of people around it.. ;)
Other than these. I am prefectly happy with my car. :D
HA its a japanese Tuner and tape player.. dont have any tapes and cant get Aust stations... Fcuking thing!
There is an easy (and cheap) solution.
You can get a handy little frequency converter that plugs in between the antenna and the radio.
It converts all the frequencies (shifts them up or done) so they match the Japanese range the radio recieves.
I have it in mine and it works quite well, the only flaw is that the radio still displays the jap frequency so for example 105 may display as 97 :)
well.. mine seems to over heat every so often.. it'll be fine for a while.. then boom.. it will sky rocket to the H mark and steam will piss out every where. I just had the system checked etc because it shat itself a while ago... damn thing.. just did it again tonight..
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
