From everything I read on the forums, the r32 gear box is the same as the r33, the r33 is just a newer version.
The R32 GTR can be run on rwd mode because there is no loading on the center shafts once the 4wd fuse is pulled out. This is not true for the r33 or r34 due to their upgraded 4wd system, sorry I don't know exact details here but it has been covered plenty of times before. Use the search function or google if you want more detail. Thus, people drop the center shafts for an r33 gtr to run in rwd mode during dyno applications.
because normally its the other way around, people's r32 boxes die and the cheapest option is to find the newest r33 gearbox possible to fit into their car.
try searching for r33 gtr in rwd mode or dyno
The power of google and wikipedia
"The R32 could be switched from AWD to RWD by removing the 4WD fuse, but R33 and R34 models had to have the front tailshaft removed, or the centre diff can be depressurised for 'towing mode' as specified in the owners manual."
The point is, it isn't the gearbox that is responsible for the awd to rwd ability for the r32
Edited by s2d4
No I've put a r32 gtr box in my R33 that was rebuilt with os giken gears. You need to keep your R33 transfer case though or else you'll have no speedo using an R32 one (R32 cable speedo, R33 electronic speedo) other than that they are fully interchangeable.
Also R32s have no preload on transfer, R33 and 34 does so you need to drop hydraulic pressure to the back of the transfer to safely get rwd (modify line to back of transfer)
Edited by BK
You can use the r33 transfer case, just pull out the speed sensor and put in the cable drive unit in.
Also you may need to switch the front input snout cover to change from push type to pull type clutch as used in the R33GTRs.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
