hey guys i have a crashed r32 gtst wreaking. most panels are f**ked but still has good doors boot rear bar and rear pods. most of the car is for sale apart from front brakes.
in devonport
motor, box, loom, computer, fuel pump and anything else to do with the motor for $1400 ono
indicators in good nick? pics of whole car if possible?
how much for box seperate?
drives side one maybe i'll have a look. i'll put some pic up soon and i'd rather keep the box with the motor at this stage mate but i do have a spare one at my place what would you be looking to pay for one ?
in devonport
bonnet is all good has no dents. black $70
LH side door has no dents $40
RH has a dent near door handle $20
door window glass $25 each
rear window $40 (pull out your self)
little side windows $30 each (pull out your self)
boot lid has small wing on it $50 (no dents)
tail lights $20 each
rear bar $40
rear pods $40
rear brakes $50
full interior just ask for prices on what you want. (has not got center console bit around gearstick)
pictures will be put on tomorrow for any thing else not listed pm me for prices thanks
Shot gun rear pods, taillights (if they come complete with surrounds), rear bar (if complete with reverse lights), fuel filler lid, and also what condition are the door/window rubbers in if perfect I'll have those too and also front windscreen moulds/surrounds the plastic bits. Cheers.
Pm sent.
Edited by krayzie32
Pm sent.
Edited by krayzie32
I'm down Hobart mate, can you post please? or pm me your number & i will call you? Or you can contact me on 0419525562..can I also get the 8 bolts i think it is with them..Bolts that hold hinge to bonnet and bolts that hold hinge to the wall
Edited by Baz_R32
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
