Hey Guys,
Does anyone know of any places in Brisbane that do 4WD dynos and don't want testicles as payment? I want to get an at the wheels measurement of the power from my GTS4 so I know what I'm working with/towards for upgrades. I see a couple of places charging by the hour, but would it really take an hour to just to measure the power?
I would prefer Brisbane, but don't mind an hour or so drive if it saves me enough money. They don't even have to be an "import" garage, even just anyone who does custom fourbies that has a dyno. I don't need any tuning or anything like that done, just a simple power check.
https://www.sau.com.au/forums/topic/321042-needing-some-help-with-dyno-places/
Drop the drive shafts man and just get any normal dyno tuning house to do it. 4wd dyno's are an absolute rip. The read outs are the same as well. Confirmed this a couple of months ago when brandon got a dyno done. So fk 4wd dynos breh and save some money :)
No Idea on how much any of these charge, but these places all apparently have 4wd dynos. What you want is a "Power Run".
Advanced Performance Centre
2928 Logan Road, Underwood
Contact:Nic
Phone: (07) 3341 7223
Email: [email protected]
Website: www.apc-racing.com.au
Bob Romano Performance Motors
387 Lytton Road, Morningside
Contact: Chris
Phone: (07) 3395 8255
Website: www.bobromano.com.au
101 Motorsport
Unit 1 / 10 Judds Court, Slacks Creek
Contact: Grant
Phone: (07) 3209 5855
Website: www.101motorsport.com.au
999 Automotive
Unit 3 / 806 Beaudesert Road, Coopers Plains
Contact: Lochlan
Phone: (07) 3272 9992
Website: www.999automotive.com.au
Performance Injection Tuning Services
Unit 10 / 42 Export Drive
Molendinar QLD 4214
Australia
Phone : 0411 34 00 33
Matt Spry
+1
Matt Spry is probably the best tuner in brisbane, dont mess him around though make sure your car is 100% ready to run
Excellent, thanks to everyone for the suggestions! I wasn't aware that a rear wheel reading would be the same as an all wheels reading so that's a big help :ninja:
I thought over $100 and being charged by the hour seemed excessive. Now I know to ask for a power run. I have lots of phone calls to make now.
Thanks again for all your help everyone. Mods I have copied all these suggestions out, so you may feel free to close this thread if you need to.
Godzilla would be another recommendation.. in Tingalpa too.. he's now a sponsor on here so i would send him a PM and see what he says.. he installed and tuned my PFC originally so i also highly recommend him.. great bloke ... and you get to check out that sexxx of a 32GTR he's got...
oh, just a power run?
list your mods we can probably guess roughly what your pushing
Your guess is as good as mine on that one. This car keeps throwing out little treats every time the guys and I work on it. I was told it was completely stock, but that was BS. The latest puzzlement is the turbo, we have no idea what that is.
That's kind of why I want to run it and see what it puts out, to see just how unstock it is without pulling it apart.
if you take off the heat shield can you see the id tag? that would tell all
probs would make 170-180kw. what your aim?
bang for buck
- gtr inj
- fuel pump
- rb25 turbo
- dump / front
- intercooler
- nistune chipped ecu
stock ecu is limited around 200kw.
Edited by 32_Dave
yo
from what ive read over time im going to lock in an educated guess
i say 140-150kw as is (i havnt had a good look at your car in ages bro)
-exhaust
-pod
-fmic??
and then 170-185kw once all "bolt ons" are fitted and shes been tuned
-full 3" zorst
-pod
-fmic
-fuel pump
-rb25tubz
-dr drift (or ROM) ecu/nistune/emanage/adaptronic/etc
-ebc to 12-14psi
-gtr injectors
yeeeeww :P
let me know how it goes man! goodluck
