Hi there guys, maybe i'm a bit green at you guy's terminolagie but what does rwkw stand for i've never been to a dyno before is this where this term originates. If the spec's fof a 250GT state 215ps@6400rpm and 27.5KGM@4400 what figures should i expect on the dyno if my ride is bog std.As for my 1/4 mile time i don't know it but in auto ,normal, i only get to around 120km/h and in manual,triptronic,with the power light on i only get to around 130km/h and in both cases absolutely no wheel spin. Maybe i don't know the technique of getting off the line, cheers
RWKW = Rear Wheel Kilowatts
The figure of 215ps is "at the motor". When reading power figures on a dyno, the output is substantially lower, due to drivetrain loss (google it).
215ps = approx 160kw. You would expect this to be something like 120 RWKW, but its impossible to say without putting the car on a dyno.
Ach! 200 from a 350, not easy at all... NA's arent cheap to mod for power, the 190 achieved above is pretty good and unless you've got cash to burn i'd settle for that.
After what you've got its going to mean a bit of head work and cams to up air flow and also some ecu work to try and tweak the tune and up the rev limit.
After that its a case of hoping the internals will cope with the load, and if you need to sort out internals, then you may aswell up the displacement.
After all the above.. you may aswell have just thrown a turbo at it and run low boost and gained better results.
The comment made about nos is actually not a bad one. A small shot delivered not too close to the plenum wont stress the engine too much, is cheap and effective.
tbh tho, if you want high performance out of an NA on a budget, you bought the wrong car.
Thanks alot,cheers
Not necessarily modding on a budget or anything im satisfied with the car as it is was just itnerested in what it would take and what could be gained its good to know that i can get to 190ish with some bolt ons...does seem that turbo is the way to go if i want more power in the future though =P
  • 3 months later...
Just got home from the Dyno and i got 191rwkw. Mods Popcharger with Z Tube, Plenum Spacer, light wieght Pulleys, Extractors and a Grounding kit.
I Dyno the car stock when i got it and had 163rwkw. So about 28kw of mods. 9 more to go :cool:
Do you mean light weight fly wheel or did u actually replace the Water Pump,Alternator Pulleys???? Do u have a link of what u did?
Cheers
Watch this space Iv got a workshop who deals in those quafie LSDs I posted about earlier getting back to me on a price next week hopefully. I will be hooking up a 50/70 shot of NOS once I have a diff that will actually get the power to the ground
Found some webpage on google late one night with some guys auto 4 door G35 pulling a 12.9 with nothing more than a catback + a 75 shot. He was using stock spark plugs as well
I remember a Guy NSW SAU got a quote from reputable Sydney workshop for HKS Super charger KIT, Drive in Drive Out job for something like 7K [i think was the figure]
apparently the 350Z twin turbo kit can overheat the 350GT for some reason and needs extensive modification to fit was the reason he went super charge
Last time I was @ QR there was a guy with a supercharged 350z with a 5 speed auto
I know his car had a supercharger/intercooler, the exhaust looked stock. He said it made 215 @ the wheels.... and it made around 140 stock.... Dosent sound right to me when my V35 with a catback makes 170 with the 5 speed auto.. oh im talking about rwkw
I just got my 6MT dyno'd at chip torque.
Only has grounding kit and fujitsubo exhaust (upto the y pipe, not cats).
Made 158 rwkw, the guy said that the air fuel mixture was good, torque was good and showed no reason for a low rwkw as i said 165-170 was the norm...
What is? Surely the manual has more than 5 speed right?
Well im going to get it dyno'd again after i put on:
Stainless Y-pipe
Stainless reinforced Headers with heat wrap
HFC with resonators
Motordyne Basic Plenum spacer
Z-tube
Pop charger
How much will i get with all that?
How hard is it to put on lightweight flywheel?
Dyno numbers depend on the dyno. Different machines with different operators will give different readings. For example my car used to pull 180rwkW on CRD and Unigroup's dynos here in Sydney, but only 170rwkW on APS' in Melbourne with the same mods/tune. They all used Dyno Dynamics in Shootout Mode.
All that should matter to you is the difference pre and post-mods, as a percentage, and what it will do in the real world. You should only be concerned that your car is making less power than everyone else's if you run back to back rolling acceleration tests and you're significantly slower.
You should be able to hit 200rwkW on "happy" dynos with all the bolt-ons, and a set of cams. I've got everything bolted on to my Z33 and, on CRD's dyno, I got around 195rwkW I think.
If I had a set of Step 1 cams in my engine so it would rev all the way to 7200RPM (it chokes out at 7000RPM right now, and levels out from around 6800RPM) 200rwkW on their dyno shouldn't be impossible with otherwise standard internals. Bear in mind that's on a 280ps engine - on a 300ps engine I would probably be hitting 200rwkW on their dyno by now.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
