hey everyone just let all you p plates know im going 4 it lol
im going to be the dickhead who is going to have the fast rb25de haha
list of wat doing
port polish head
saved 20thou
heavy duty springs
titamuim seats
cramic head gasket
big cams
adjustable tomei cam gears
hpc coated headers
greedy type plemum
14m o ring fuel rail
fuel pressure reg
800cc injectors
boch 040 fuel pump
hks mushroom pod
themo fan
haltech e11v2
and see how things go mite do 30 bottem end and over size piston but thats a maybe
thats all i can rember anyway will be dyno in about 2 weeks lets us no wat you think.
and estamated power
cheers
https://www.sau.com.au/forums/topic/321529-going-all-out-on-rb25de/
lol at injector size
bit optimistic maybe
heh 800cc would flow 800hp at the flywheel .. from an RB25DE .. mmmm yeah.
To be honest, I'm not sure why the OP is bothering. Ultimately, he's going to end up with a car that's going to be an engineering hassle, from what I understand in most states modified P-plate cars aren't legal, he hasn't considered other upgrades like clutch, brakes or suspension...
At the end of the day, he's better off holding onto his cash, and waiting to buy a turbo that will be able to get more power for less financial outlay. Building a fast/high-revving NA is fun, sure - don't get me wrong - but it's not cheap, and you compromise the reliability of the engine from having to rev it to get the power. Ultimately you're going to get a better performance result for less money and have a more reliable motor from forced induction ..
Additionally, by buying a turbo car outright, you already have bigger brakes, an engine designed to handle more power, etc ...
if it was me this is how i would work out what to do
"hmmm, i could spend... lets say 10k, building a super powerful rb25 (or 25/30) that might end up making 200kw that is a pig to drive on the street,
OR
i could sell the natro car, buy a turbo'd one for about the same money and have a stronger gearbox, LSD, bigger brakes, etc, and then spend about 6k and have up towards 300kw that is much more street friendly."
i know which way i'd be going
oh i forgot to put something in my post, so i'll quote it to fix it up
OR
i could sell the natro car, buy a turbo'd one for about the same money and have a stronger gearbox, LSD, bigger brakes, etc, and then spend about 6k and have up towards 300kw that is much more street friendly, and then spend the remaining 4k on beer and hookers."
This thread almost seems like a troll...
Anyway, If I was a P plater, and had some drug money to blow on my natro skyline and didn’t want popo attention + wanted a perfectly tame street car;
I'd go an RB30 Bottom end, SPOOL 3.4L stroker kit.
Deck the block so the pistons rose flush to the thickness of the compressed stock head gasket, aiming for a compression of around 10.5:1 (assuming its your daily, this is to keep it 10.5-11:1 Compression ratio
Porting/polishing/oversize valves/enlarged ports
Mild cams, something between 255-260 range, with adjustable exhaust cam gear, and VCT controller (if the ecu cant do it)
Stock Headers (maybe some internal work), stock Heat shields/covers/brackets, Stock GTS-T Exhaust, Stock Air box with high flow filter
Stock intake manifold, but modified somehow to get more air in it, maybe machine out the throttle body and fit a slimmer knife edged butterfly.
Tuned with aftermarket management of your choice (sneakier the better, retaining stock loom/sensors etc would be smarter)
And would probably have power somewhere in the vicinity of a stock GTST, with a car that just as streetable, with no one knowing any different.
Keeping the rest of the looking as standard/low key as possible (stockish ride height with stiffer springs/shocks, stock/non flashy rims, lsd, quiet car, stock interior bits etc) and the car would actually be something worth having.
And thats why putting that much money into a car like that is a WASTE, "oh i spent $20,000 to get my car to the stock turbo level and when i get EPA'd, people will know its illegal anyway so i would have been better driving a turbo one around"
I say bullshit to all that.
Replace fuel system to E85 friendly one.
Run E85.
14:1 CR
ITB's
Rise the max RPM a little but keep a meaty mid to high end torque and power curve.
Lighten and balance everything
Drop every single gram of weight out of the car.
Thats what an "all out" rwd NA should be like
Edited by GTS4WD
wtf, like you are going to get EPA'd.
It could make a f**kload more than a factory turbo, the reason I said otherwise was because of the things you would have to do to keep it looking stock (exhaust, manifolds, throttle, intake pipe, mild cams/compression), sounding stock and street drivable would dampen the power ALOT. I have 4 cars, a built RB30DET, an RB30DE, an RB25DE+T, and an RB30E+T. All are completely different, and have their places.
Not everything is about the most power possible, the 30e+t does a good skid, but its lazy and wont rev. The RB25D+T is incredibly responsive, great on fuel, and is just a great daily car. The RB30DE is just heaps of fun - especially in the twisties (so is the 25de+t though), makes a mean sound, gets up and goes, pulls beautifully linear (With a great surge up top) and just screams. While the RB30DET is good for making people shit their pants in a straight line or going sideways.
If you’re a P plater, have heaps of money to blow for shits and giggles, and want to make more power without anyone finding out, that’s the sort of thing you can do. The car will drive well, pull hard and will make decent power. Once you’re off your P's you can let it breath again, put on some visible bolt ons and make a fair lump more power.
People have spent a lot of time and/or money on a lot worse cars & engines to make less power. I can’t see why it couldn’t make a fair amount of power, somewhere between 160-200kW at the wheels depending on how much you push it with cams and compression (talking about the 3.4L). That’s a car happily in the 13's, with a suitable amount of power for it to be quick on the street and for some fun around the track/through the hills/twisties.
Too much power is not always a good thing, it takes the fun out of things, its good on occasion to test yourself out, but I’d much rather drive my lower powered 25DE+T & RB30DE (both have equal power - around 160WkW) than the RB30DET on anything but a straight line.
Everyone keeps forgetting we are in the N/A section. Also, just like everyone making power with a turbo doesn’t have forgies and 10g’s worth of supporting mods, you don’t have to N/A either. Yes you can have a nice wish list, but at the end of the day if you don’t f**k it up, you can still make good numbers.
Just like you can strap a GT30 on a stock RB25DET, run 1 bar, add supporting mods such as injectors & management. You can get an N/A motor, and spend just as much by bumping up the compression, running some meaty cams. With a turbo motor, you can get a stock RB30e bottom end, throw an rb25 head on it, a bigger turbo and you’ve got an rb30det. Just like you can get an RB30 block, give it a buzz, drop your rb25de slugs in it, new ring and bearings, once again cams, and your making some bloody decent numbers. Yes you can spend thousands balancing it, putting lightweight pistons and rods, headwork etc – just like you can with a turbo motor. But at the end of the day, with just the simple 3L, cams, compression and management, with breathing mods, somewhere around 150kW at the wheels is where you’re going to start.
Obviously if you’re trying to make the most power humanly possible from a certain base engine, FI is the way to go, but that’s not always what everybody wants.
Edited by SKiT_R31
list of wat doing
port polish head
saved 20thou
heavy duty springs
titamuim seats
cramic head gasket
big cams
hpc coated headers
greedy type plemum
fuel pressure reg
800cc injectors
boch 040 fuel pump
hks mushroom pod
themo fan
haltech e11v2
platum plugs
98 octane
spitfire coil packs
and estamated power
and its is in a turbo shell so i did my research got the 5 studs and r34 braks and bc coil overs
cheers
cheers bro good info to know very helpful unlike some others and like he said we are in the n/a section so dont watse your time i really dont give a
shit wat u say im rackin it in and got a chick so i need somthing to blow it on and its sweet fun at the end of the day buildin car and for a change
doing somthing somone hasn't done before.
yeah how about you just keep thos retarded comments off my post because for one i have done my resarch and turbo/non turbo 25 heads are the
same so as soon as im off my p's i cam just bolt that head onto somthing sick with diffrent compressions ratios and stick a nice snail on the side hah it just means i can have a resonble car for the next 2 yeah
look out honda boi you dont know wat you could be dealin with ahahah deff should race tho ahhaha
it must be school holidays again :)
agreed :)
its not as easy as 'just bolt a turbo on and off you go' when you get off your p's. it will cost you even more money to get a turbo working properly on it. i know its your money and you can do what you want with it but please think about it a bit more. the end result will be that it wont be very fast and when it comes to getting a turbo on it it will cost you a hell of alot more.
My rule of thumb is: if you can't spell properly you don't know what your talking about.
Also from your posts you have made it reasonably clear that you haven't done your research.
Why are you using 800cc injectors?
Why do you say you "might" go for a RB30E bottom end when the engine will be dynoed in two weeks?
How long do you think it takes to pull the engine out, rebuild it, put it back in, wire it up, book dyno time, get it to the tuner, and tune it properly?
How do you think the police are going to act when you say that the turbo shell hasn't got a turbo motor?
For the most part you do know that they will automatically assume that this is a performance mod?
If you could please answer all of these legitimate questions for me, I and everyone else here would take you far more seriously.
Edited by R33_Dude
My rule of thumb is: if you can't spell properly you don't know what your talking about. that a good rule :P pfft
Why are you using 800cc injectors? it was ment to say 660cc my misses didnt understand me
Why do you say you "might" go for a RB30E bottom end when the engine will be dynoed in two weeks? its sittin at the rebuilders i just have to say do it and he say 3 days to do it
How long do you think it takes to pull the engine out, rebuild it, put it back in, wire it up, book dyno time, get it to the tuner, and tune it properly?well it takes me 3 hours to take the motor out and the rest its really not that hard f**k paying somone to do somthing so easy and the really depend how good the guy is at tuning
How do you think the police are going to act when you say that the turbo shell hasn't got a turbo motor? well i had been driving it for 6 month before i pulled it down and got deffected 2 and not once did they say shit so meh f**k the police if not got a mate thet will engerneer it and pulled over many of time and they never looked under the bonnet
For the most part you do know that they will automatically assume that this is a performance mod?well they can suck my dick im not some dumb ass p plater who goes around being a dick head and sure they could but like i said f**kem dont let thos fags push us around
If you could please answer all of these legitimate questions for me I and everyone else here would take you far more seriously.
happy to answer anymore qustions
Thanks for your eloquent reply. Yes, I do have more questions and a few responses.
that a good rule thumbsup.gif pfft
It is when communication is occurring in the printed medium. Your spelling and word choice makes me think (not necessarily in the following order): arrogant, uneducated, young, and inexperienced. If you spelt properly it would seem more enthusiastic. Your hostile too, which makes me think that your not out for advice, just to troll.
Okay well, 660cc injectors flow to approximately 600HP on a 90% duty cycle (approximately). Why not use stock turbo injectors? Save yourself a wad of cash. There's no way you'll make over 200kW. Fair enough use 660's if you have them sitting around.
Not hard to get someone to do something so easy huh? Why not tune it yourself. If you want a good road tune (particularly on a N/A engine) expect a few days worth of tuning for a solid tune at all revs, all gears - response is meant to be the aim of the game.
EDIT: had to spread this over two posts...
Edited by R33_Dude
well i had been driving it for 6 month before i pulled it down and got deffected 2 and not once did they say shit so meh f**k the police...
Really? How immature.
Just ignoring most of what your saying there and straight to the point: if your "mate" can engineer it, why not get it engineered from the start?
Now including the rest of what you said: the law is that they can defect your car. It is not "pushing you around". Its the law, and it means conforming to manufacturer specifications and a variety of other requirements. I know of at least three people defected because the traffic patrol counted the wheel studs - didn't even need to pop the bonnet. Save a lot of pain and get it engineered from the start - all of my cars are.
So in summary I think you will make approximately 140 - 150 rwkW on a good day and and with an optimistic dyno with a lot of money spent on unnecessary things. I'm not trying to stop you or discourage you from going N/A I'm just saying think about it a bit more.
If in doubt talk to skit R31 - I love what he has done with his RB30DE.
Edited by R33_Dude
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
