18 x 10 CCW C10 wheels
anodised black
seems to be reasonable brake clearance, more than 6mm at its tightest
offsets difficult to judge whilst suspension is not under load but should be aggressive without sticking out too much by my estimates, fingers crossed for when the slicks are mounted and the car sitting at ride height.
https://www.sau.com.au/forums/topic/321550-complete-custom-wheels/
hey John,
they are 10 inch wide with 6.6 inch backspace - bit rough to convert but maybe +27mm??
welcome to try them on anytime if thats close :cheers:
though with the times your car is getting already i dont know if I should!
hmm that offset might work :D but might have to come and try it out one day
can u weigh the wheel as well ? cheers
mind if i ask how much they are ? and where to get them from ? pm me if u dont want the world to know the price
as i found out at superlap, u can never have enuff tyre on the road
offsets works well up front. will be tucked in at the rear. I reckon I will need a 15mm spacer but will wait and see.
plenty of brake clearance, tried to demonstrate with backlight as I know many of you are interested
thanks Duncan.
only went with this set up after you had done all the hard work trying various wheel/tyre combo's
i would recommend the CCW for anyone who is interested in 18 inch track wheels and is concerned about brake clearance
  • 3 weeks later...
The new wheels and 27/68/18 second hand michelin porsche cup slicks worked well today. As did all the other mods Trent and the boys down at Mercury have been frantically finishing off for today. more on that some other time.
here are some pics of the wheels on at the track. Just over 3 degrees camber, about 15mm lowered. no rubbing.
55.67 on the sprint and 58.12 on the Clubman at QR
    • haha don't worry I'm sue you've got more fun ahead buying a 30 year old turbo car....but at least you are in the right place to ask
    • some days eh? The keyless entry and interior light on/off with the key will be controlled by the Body Control Module, but I'm not certain where that is or what it looks like (you might get lucky with a search to get a part#, which could be printed on it). I'd start at the A pillar/ Under dash/kick panel on the driver's side
    • It might be hit and miss, but Nissan Genuine Parts and Pitworks are not the same thing, although both are available from Nissan Dealers with Nissan Part Numbers. Nissan Genuine Parts are the OEM stuff, Pitworks are their attempt to get people back from generic parts makers
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
