Haltech Platinum Pro
Nistune
Power FC
D-jetro?
Im heading out to my tuner to have another chat with him..i left there last time with thoughts in my head "im going haltech"....i cannot get over the fact that nistune is so friggin cheap......
Im happy to pay whatever for a good solid tune...but the price difference in units + tune is alot to say the least...
I will be running about 300rwkw...
Friday night....time for arguments
Aiden
https://www.sau.com.au/forums/topic/321563-just-cant-decide-on-a-computer/
remember with the nistune and the powerFC that you will also need a Z32 AFM if you do not already have one, factor that into the cost vs the other options.
If your tuner is most confident with the haltech units you are probably best going with that.
Depends on what you want to do with engine. If you want a high reving engine for dragracing use (above 6400rpm) and need more rpm points (where ignition timing, amount of fuel injected changes) above 6400rpm, Haltech or PowerFC would be a better choice. If road / racetrack engine and not going to rev above 6400rpm, stock ECU will do the job. Also some aftermarket ECU's like Motec ECU for example is suited to competition use and can change troublesome sensors (CAS, etc) which can't be done with stock ECU, PowerFC ECU (have to run stock sensors, etc). Except for AFM that can be changed to Z32 AFM, etc. Also aftermarket ECU's have onboard boost control, launch control, etc. Just too many features to list.
Usually more rpm points = rpm points closer together and result's in a smoother reving engine due to engine doesn't struggle to rev between rpm points, but takes longer to tune which cost's you $$$.
Stock ECU with 6400rpm / 16 rpm points = rpm point every 400rpm.
PowerFC with 6400rpm / 20 rpm points = rpm point every 320rpm.
Haltech ECU with 6400rpm / 32 rpm points = rpm point every 200rpm
Motec ECU with 6400rpm / 40 rpm points = rpm point every 160rpm.
Can see why Motec ECU is popular on dragracing, racecar, etc engines.
If engine is RB25DET, Haltech, Link or Vi-PEC ECU. Motec ECU if you have the $$$$.
Edited by SKYPER
i think i need something in between haltech and power fc! haha, i don't want to run an afm.....i don't even know why...i just want to get rid of it, that, i don't even know why....4inch intake!
Im probably going to just have another chat....power fc is old school technology i would like to try get something newer, my tuner loves the haltech, i haven't read much about link.....thats next on the googles!
Between Haltec, PowerFC with price???
Vi-PEC ECU -
http://www.vi-pec.com/
Link G4 ECU -
http://www.linkecu.com/products/engine-man...-ecus/g4-xtreme
Although after watching the Envy Imports R34GTR with Haltech ECU, kind of like the Haltech ECU -
Edited by SKYPER
powerfc
plug in, drive to tuner and your done
lots and lots and lots and lots and lots of tuners (you can pick best price, best support etc)
simple to use hand controller
lots and lots and lots and lots and lots of documentation (see my sig, powerfc faq and online hand controller emulator)
probably the cheapest from the bunch
be sure to note some points when picking an ECU
the brand of ECU means ZERO when you say you want XYZ rwkw
any ECU option can and will make power, even a remap can make 400rwkw
so ignore "rwkw" as a deciding factor, ie the MOTEC wont make 400rwkw and the powerfc will only make 385rwkw
djetro means map sensor based ECU which guesses engine load from pressure
ljetro means air flow meter (like your stock ecu) which measures air coming into the engine
ljetro is fine in your case and will work, there is no need to change to map sensor to over complexify it or add more cost
# of rev and load points is a pretty minor fact, most of the ECU options have reasonable load points and axis mapping
ie you shouldnt go for XYZ ECU as the load point are 350rpm vs 325rpm - this is a negligable difference for a street car
Mmmmm....I may be wrong but I think you mean you need a Z32 ECU, not AFM, to run a Nistune.
yes if you want to aim for 300rwkw you will need to sell the stock AFM and buy a Z32
but if you want to use a djetro ecu then you need to sell the stock AFM and buy a map sensor
you could sell the stock AFM for $50
and buy a Z32 for around $200
or
and buy a map sensor for around $200
so its much the same really
All these ECUs will do the Job just fine, Nistune is hard to go past with is control and price, Haltech is really something special but over kill, PFC is very good tho I find Djetro versions a pile of crap.
If your Racing Id go Haltech if its a wild streeeter Nistune, PFC are just are much more basic than Nistune but cost 4+ times the price.
ViPEC!
If you have a 33 then I would NOT look past the v44 plug in board. For $1800 it comes with a built in 3bar (absolute) MAP sensor, intake air temp sensor (to correct for changes in air density with temperature) and drops straight in to the factory case. It has a MILLION functions and there is no need to upgrade your MAF.
So when you get a PFC second hand for $1500 and buy a $200 Z32 MAF you are only saving $100 compared to getting the ViPEC brand new. However, they don't come with a hand controller, so if that is your thing then so be it.
It does however come with a USB cord and software so you can link up the the ECU, where as a PFC will need FC pro or datalogit (Extra money) to plug your ECU into your laptop (also uses a serial port instead of usb).
For what the V44 offers and the amount of support I have had so far from Ray, and Guilt Toy I know that I will not be looking anywhere else.
Also, anyone that can tune a link can tune a vipec, so if you are looking for tuners, search for link tuners.
As for the Haltech.....no
EDIT: Forgot to mention that the ViPEC also has built in boost control and launch control
Edited by Lukas 33
i wouldnt pay $1500 for a R33 Powerfc
more like $1100
yes they are no longer made by apexi, but they can be had cheaper than that, ive seen them go for $1050 with hand controller
powerfc
$1100
sell stock AFM $50
buy Z32 $200
$1250
V44
$1800
sell stock AFM $50
$1750
find some local tuners and get some pricing and find out what they tune
its not good if your local tuners dont know anything about nistune and you have one
same with powerfc, its not good havign a powerfc if all tuners near you dont know how to use it
so be wise check before buying and see what they reocmmend and what price to tune as well
interesting as i reckon the d-jetro its one of the best ecu's around especially on 2JZ, RB AND SR, no dramas with high hp, easy to tune and returns excellent ecomony when tuned right.
Why are Wolfs so bad?
I have had PFC's, Motec, Revo and find that Wolf is as good if not better than any of the others.
Would not liking wolf come down to your lack of knowledge of the product or is is actually based on experience because everyone I know that has a wolf has never looked back.
Having used various ecu's I can personally say coming from a consumer that I would pick wolf again, infact I would go as far as to say considering $$$$ wolf would be my first choice.
Everyone needs to remember that an ecu (the ones mentioned above) is only as good as the person tuning it.
I have Wolf V500 on My Racecar and theres nothing wrong with them, Bit to complicated for many tuners.
Support is not good now so I don't sell them anymore but still a good unit.
Djetros are to hard to pass emission tests and thats now a major factor in WA, Power etc is no problem, reliable emission output is not good.
Ive had 2 and my series 6 was used for the deveopment of thier version 4 (via mildren rotory in adelaide), i have quite a few few reasons for not liking them and continual isues with firmware in my v4 and massive timing drift was only the begining of my hate for them..
My main hate is the large percentage of people who come in with wolf ecu's have bounced from shop to shop trying to get a decent result without getting something they consider up to scratch.
As i said previous i dont waste my time with them, i send them to a wolf dealer and if they are not happy with the results and come back we swap it out for something else.
its only my opinion so either way it makes no difference.
I am also in this situation and i think i am leaning towards the haltech for my 33, had a good talk with both haltech and vipec guys at superlap today and was impressed by the haltech but dno yet have to tlk to some tuners hahaha
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
