I've heard mixed reports about spacers.
Some guys say there's no issues, some say just get the rims with the right offset.
There's only a couple rims I really like and will cost over $2k.
For now I'd rather put that into tyres.
I currently have 17 inch Sterns 235+35 and 255+37. I'm pretty sure this seems to be the ideal offset for legal fitment.
My camber is relatively mild and the top edges of the tyres sit about 13mm inside the guards.
I'm about to recondition these rims with a repolish and repaint and wouldn't mind having the tyres flush at the tops, and maybe have zero camber on the rears for optimum traction as this IS the biggest issue with the GTS-T.
I can get 5 mm floating spacers or 15mm bolt ons.
Just wondering if anyone can explain the difference in handling I might expect with those 2 options.
https://www.sau.com.au/forums/topic/321963-spacers/
depends what you do man
spacers are fine for city laps and shit but i wouldnt use them out at the track
don't get me wrong, people do and have no problems but theres always the chance of the nuts coming undone, plus the extra load on the studs
15mm are pretty mellow though, i would probably rather use 15's that a 5mm slip on... just take them off if you're gonna do anything serious
https://www.sau.com.au/forums/topic/321963-spacers/#findComment-5252992
I was researching about spacers recently and found this site you should have a look at. Make sure to use bolt on hub centric spacers.
http://www.ozhonda.com/forum/showthread.ph...ty-and-legality
I have known mates use spacers on the track with no issues. As long as they are secured properly on the centre of the hub there shouldn't be any problems. As a result I've recently ordered 25mm bolt on hub centric spacers that'll make my wheels kiss the guards =D
https://www.sau.com.au/forums/topic/321963-spacers/#findComment-5258404
they are tyre sizes not rim widths.. but anyway like everyone else said if you must use hubcentrics not slip ons. you wont have handling differences as such but you might find the 15mm will push it out further than you want, best thing for now would be to leave them alone dont spend ANY money on these wheels be it a polish and paint or spacers save that 500 or so and put it towards the next set of wheels why fix up something u dont want anyway
https://www.sau.com.au/forums/topic/321963-spacers/#findComment-5258426
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
