ok, i have an R32 GTS-T and a full 3 inch exhaust with a cannon. i have seen my mates GT-R make meter long flames and just wondering why mine doesn't?
i know it's to do with unburnt fuel and a hot exhaust igniting it, and mine makes some fery loud pops! but i've just never been able to get a flame! i have had mates repeatedly rev it to see... some pops are really loud cracks and some are deep thuds. anyone know anything about this?
https://www.sau.com.au/forums/topic/322087-why-no-flames/
get a b r limiter , they are like the mad core . the flames make your way car faster . but it drifts weird if your exhaust isnt in the middle . pull the exhaust off at the dump pipe and itll make it do wheelies
+1 but my car did back flips instead of wheelies... i think i pulled to much of the exhaust off
https://www.sau.com.au/forums/topic/322087-why-no-flames/#findComment-5253297
all GTR's need is a gutted cat or de-cat and you will get flames.
mine lets flames out a fair bit with de-cat but as others have said over time the rear bar gets black shit over it which does come off but is annoying. Will probs be getting 3M clear film/sticker for rear bar protection or just chuck a high flow in soon.
https://www.sau.com.au/forums/topic/322087-why-no-flames/#findComment-5253305
Step 1: remove cat
Step 2: turn off the decel fuel cut on computer
Step 3: pay ridiculous amounts of money in fuel to burn rear bar
you forgot to add in step 4, which is "say goodbye to the exhaust wheel of the stock turbo as it gets drastically weakened by the excess heat and decides to part company with the turbo and go on a holiday out the exhaust"
also i think this pic belongs in this thread
https://www.sau.com.au/forums/topic/322087-why-no-flames/#findComment-5253314
So can high flow cats still permit flames (200 cel or 100 cel)? Or does it fully have to be no cat (too loud)? Does it work with non turbo engines? Technically it should because it is unburnt fuel and exhaust heat, unless the turbo contributes to a lot more heat...
https://www.sau.com.au/forums/topic/322087-why-no-flames/#findComment-5254595
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
