  • Replies 78
Posted Images
do we need to organise the snags and sundries for the BBQ
if so, should probably go visit austral meat and get them direct from the wholesaler n save a couple bob
will need bread, sauce, mustard, onions n all the other stuff too - best to get that before the event
-D
i use Frew trading for wholesale meats
Where are they? Austral is just around the corner from the Drive in at Gepps X
Should probably talk to nigel and see if we can get the cash before the day, go shopping the day beforehand and do the food prep (chop stuff n tupperware it)
Need:
Mustard
Sauce
Onions (lots, chopped)
Bread Loaves
Olive oil
Sausages
and maybe mince patties too? *shrug*
Serviettes
-D
patties don't go down that well
onions can get from galipo foods or other food wholesalers
i see you like mustard as that's #1 condiment :):D
Frew is at dry creek
KK australs a bit closer, i figure if we're gonna be buying for repco we may as well get the meat and then everything else from the same supermarket so they can claim the reciept on tax.... bit of garlic might not go astray... if i was doing sangas and bread for members i'd have to get cheese and bacon but for an open day that's just too damn expensive
one other thought - bbq sauce?
-D
I was told by the boss that she will be giving us $50 towards meat, and providing the BBQ with a full gas bottle etc. So I'm thinking if the club purchases the supplies first, they could be reimbursed on the day?
I would like to see any profit made from the snag sale going back into SAU.
$50 of sangas will only go so far
you'd be looking at a $20 sangas, $10 bread, $5 onions, $10 sauce, mustard etc $5 serviettes
thats my estimate for a $50 budget, and even then it might not go very far
be that as it may, since im just appearing with the car on the day, i take no responsibility for how any money is spent. advice given freely.
-D
Its just a small bbq..
I asked Damo, and in turn Steve has offerend to cook the BBQ, so he can organise it how he wishes.
This is not an SAU event, just a favour for a local business.
Steve: you have a PM.
ok PM recieved
Im having issues with my car atm. nistune isnt working right and I'm only getting half the power I should be - cars probably going to be in pieces this coming w/e... should replace me if u can pls Nigel
-D
good stuff! This is what i like to hear!
BBQ, gas and cash will be provided for meat, and the club has permission to pocket the profits!
I will PM people when I get home with exact details.
thankyou all!
Sounds good Nigel.
Of course, undoubtedly more snags will be required, but I'm certain there would be no objection to the Club purchasing extra where required. Seeing as the profits will be going back to the club anyways.
Steve/Damo, I'm assuming you guys have taken the BBQ role. Get whatever snags you guys judge to be required for the day (cans of drinks also).
:yes:
Oh, and my Stagea is now 100% available for this display Nigel, should it be required.
Sounds good Nigel.
:yes:
Stag love... cool - I'm only getting 130kw atm... something is seriously borked
I really hope I havent blown a turbo
-D
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
