hey got my r32 up for sale! has had heaps of coin spent on it over the last 3 years ive owned it...makes sweet power with the hks 3037 gt pro turbo! spoools hard by 3500rpm and holds till 8200 :( will b sad to see it go but now im looking for a lil more of a cruiser! so ne one thats interested plz dont hesitate to txt me and ill tell u more about this crazy machine!
mods:
s1 rb25
acl race series pistons rings bearings
npc built clutch
stainless manifold
hks 3037gt pro s turbo on 6b00st mani
hks 50mm gate with screamer
respray morpheous purple
advanti chrome 18z
viva garage full kit
carbon vented bonet
vi-pec ecu
coilovers tein coilovers
front mount
shimed diff
drift catch tank
aftermarkt FMIC
flared and rolled rear guards
front(mines) and rear(whiteline) strut braces
recently replaced exhaust valve guides, valve stem seals and lifters (under 1000km) new head gasket, exhaust gasket, rocker gaskets, and intake manifold gasket
plus heaps more. makes 288kw on 15psi :( this tune was done as a quick safe run in tune around a year ago for powercruise and havent needed to touch it since!
one bad point is that the teins may need replacing. am looking around for a new set as we speak.
looking for 17k(neg) or may swap for 180sx/s14/wrx with adjustment. cheeers andy g. txt me for pics 0400341730
Edited by andygr32
https://www.sau.com.au/forums/topic/322503-fs-89-r32-gtst-rb25-hks-3037/
still got the rb20 gearbox mate? if you dont sell it would you consider selling the engine seperate?
hey mate nah run a vl-t rb30 box. reconditioned. havent got the 20 box. ah and as for selling the engine separate i hope it doesnt come to that to b honest.
hey got my r32 up for sale! has had heaps of coin spent on it over the last 3 years ive owned it...makes sweet power with the hks 3037 gt pro turbo! spoools hard by 3500rpm and holds till 8200 ;) will b sad to see it go but now im looking for a lil more of a cruiser! so ne one thats interested plz dont hesitate to txt me and ill tell u more about this crazy machine!
mods:
s1 rb25
npc built clutch
stainless manifold
advanti chrome 18z
carbon vented bonet
vi-pec ecu
front mount
shimed diff
drift catch tank
aftermarkt FMIC
plus heaps more. makes 288kw on 15psi :P this tune was done as a quick safe run in tune around a year ago for powercruise and havent needed to touch it since!
looking for 17k(neg) or may swap for 180sx/s14/wrx or forrester with adjustment. cheeers andy g. txt me for pics 0400341730
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
