  • Replies 155
nicknick - thanks for the timeslip (what about your car?) Also was this done in the gtr you were selling for $15K on here in the last week or so? Without being too much of a synic that timeslip could have been for a rail that missed the start then got back on it 3/4 track!!
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/2/#findComment-654242
K - i jumped the gun the car pic hadn't been posted yet. So thats your car that is in HPI GTR Special #4. That article supports your story that it still has the original box. I think you will have to admit you will need some luck keepin it together if you plan to run 10's.
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/2/#findComment-654249
nicknick that is a sweet lookin car - However I am suprised that the box lasted longer than the twin plate HKS clutch. I'll let it go with respect to your 1/4 mile run but I will say that is the slowest time I have seen for that kph (I understand your clutch was f##ked, it just seems odd that you got drive in higher gears to obtain the terminal speed). Gettin back to your comparison of the rex boxes, aren't they the weekest part of subaru's driveline eg 2 -3 good launches and they are stuffed. Anyhow, lookin at your mods you should run low11's with ease. I wish you the best at the track in the future!
PS: What was the go with that 15K gtr you needed to sell to buy a house but now you have this beast?
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/2/#findComment-654537
dean from upimports did the work, some of it, i dont know who BMT is,i know you think its odd that it run a poor time running 186kph, imagine my face when i saw the time sheet. i sold the stock gtr quick so i can invest in a good property oportunity, doesnt mater i can always buy another one for run around.
at to BLITZ i live in sydney i bought it from melbourne, that was a fun drive, think i clocked it 3 times on the way back, twice on the straight and once uphill, first time ever i a car. thanks benjiman74 for the support, hopefull i get my time that i want so i can finally have the paper to prove it.
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/2/#findComment-654792
its a T78-33D the biggest of the T78's, when the box was rebuilt like i mentioned, my mate told me there is no reason the box shouldnt hold the power, its been holding it till now and it was perfect inside( he said like new) i mean that should say something about the box after 9 years of driving. and for the low 11's comment, i think it should be possible for a mid to low 11 hopefully. we wont know till we try,...
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/2/#findComment-655361
According to the time slip, you got a 60ft of 2.393..... Either your getting heaps of wheel spin or she's bogging down....
Either way, a good launch should see you well into the elevens......
What rwkws she pumping out???
https://www.sau.com.au/forums/topic/32287-10sec-gtrs/page/2/#findComment-656936
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
