Please can I have some help here guy's. I finally got my engine turning over to try and prime up the oil system. No oil seems to be getting through the system. It got assembled some time ago and I have to say I don't think I put any oil in the pump when I put it on? Also I am running an oil cooler and currently dry oil filter. The latter I can resolve easily enough. But having read a post somewhere I recall a dry pump might not seal and draw properly? Can someone tell me how I can get around this with my oil cooler setup to try and get some oil back to the pump and get it priming. So far I cracked off one of the pipes and turning it over for a minute or so to see if all would come through but nothing. Also I will pull the plugs back out so it can turn over quicker!
Thank you
Lee
https://www.sau.com.au/forums/topic/323027-priming-oil-system-rb30rb26/
Plugs shouldnt be in if your trying to prime. The load on the bearings from compression can be enough to 'wipe' them. You can put oil into the outlet to oil cooler/filter and turn the motor backwards to let it run down and then turn it clockwise and try to prime again.
You should put a smear of assembly lube over the gears to help create a seal when you inspect it and chuck it on.
Thanks for the reply..
This was my plan. I will pull off the oil filter so I know which pipe to use and then pressure some oil back down it and turn the engine backwards a turn or two as you say. I gather there are no worries turning the engine backwards. Like cambelt riding off or something daft. I can't see it as the tensior is locked in place.
Thank you
Lee
would the bearings also be smeared with assembly lube to avoid wiping the bearings? is that common practice or am i wrong? nfi :D
The bearings should have assembly lube on them anyway. Only other way is to use oil, but thats an old practice. Fairly certain everyone uses the lube these days. But yeh thats right.
The lube on the gears just helps create suction and protect from dry wear until the oil starts going through it all.
you can take the outlet line off the block (that goes to cooler or remote filter mount) and fill it with oil, then wind the engine over backwards by hands and keep topping it up as the level drops, put about 200-500ml back down the line then reassemble. Crank engine without plugs and oil pressure should jump up quickly.
make sure you fill your oil cooler and oil filter too.
Primed and ready!
Injected some oil down the cooler line back to the pump and turned then engine backwards a bit then popped out the plugs and spun it over.. Light went off after about minute or so! What a relief!
Cheers
Lee
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
