well the 5puk sliding performance bitza clutch has let go.. well under power it has...
50,000kms 8 test n tunes 1 powercruise 1 skid pan day and its had enough haha
whats a decent clutch without going single/twin plate crap.. to support 400rwhp and drag days etc?
Edited by l0WRB
https://www.sau.com.au/forums/topic/323072-best-clutch-for-400rwhp/
  • Replies 67
true. You will have to call him. I cant remember what i paid but it was just over a grand i think. Cheaper if you have a decent clutch plate to rebuild. I warn you though he will chew your ear off.
"ill buy your bloddy clutch just as long as you shut the f**k up Jim!"
2k on a clutch that will 100% hold up for years or 1k for a clutch that might shatter itself all over the place because its on the limit.
I have a OS Giken Comp Twin plate rated at 600hp, The Nismo Copper mix one would be better for the street though imo.
OS also do a milder twin plate rated at 480hp which is cheaper.
Exedy single plate HD button....
cheap and will hold 400hp
agreed.
dispite the fact jim berry will tell you they are rubbish, i have never seen a regular pink cover exedy HD NOT do its job properly... get the early model R32 GTR one (its a lil heavier) 5 puk HD. Will be under 600 for sure.
Also, member here has had a nismo coppermix twin in his car for about 10ks, swears by it ra ra ra... I launched it once..... first non drop launch it had ever done, short hard slip at 5000rpm. say whatever you like, I know what Im doing with a clutch, it STUNK. Definately wouldnt take many of those.
Personally I buy a clutch to cop the hit and change it out more often so Im not replacing gearboxes and enginemounts every 2 weeks.
The HD button isnt too heavy and if you use it right wont smash your gearbox to pieces, also more forgiving on a short slip launch than an organic.
I put one of these said clutches in my NXR turbo 3 years ago, its still going.... who knows how many KS, how many 2nd gear slip launches... how many natio runs... how much half hour long beatings I gave it before I sold it to the noob that has it now. Still going, I see the car regularly, clutch is still holding. Same to be said about a friends S13 done in 2005.
Its a consumable in my eyes, your choice.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
