Gauging interest for the following:
8000K Super Vision Japan HID conversion KIT = $454 + $30 to $50 Shipping
PIAA Plasma Spark Blue 7500K H1 H3 HID Xenon = $100
Shipping for the bulbs if you buy 2 sets = $19 so id think for 1 set itd be around $10 to $15
The seller said if i buy 10 sets of bulbs he'll knock at least $10AUD of each set :(
The bulb sets come with 2 bulbs so you can choose if you want them for high or low beam, if you want it for both then buy 2 sets = $200 + shipping
https://www.sau.com.au/forums/topic/32333-piaa-xenon-bulb-and/
  • Replies 67
Yes mate these are 7500k globes...PIAA are the ultimate in replacement xenons
Stock standard in beamers, itll give you an awesome white light with a slight tinge of blue :rolleyes:
You wont be dissapointed :)
will they fit my stock gtr lights ?
arnt HID lights worth over 1grand ?
The kit will fit your GTR lights no probs
Same with the globes, this stuff is specifically for the R33
Can get kits for r32's and r34's if necessary :D
just wondering on the PIAA HID conversion kit thier is no logo that is PIAA or anything like that???
yeah the conversion kit aint PIAA its like super vision or something...i never said it was PIAA lol
This whole thread has been about the PIAA bulbs :cheers:
what is included in these conversion kits? will it fit a series one gtst r33? series two lights are heaps different. Are they just globes or what? The beamers have PIAA as standard but thay are proper gas lights arent they? not normal globes as such but xenon gas burners? If you want a proper xenon gas light conversion you have to change everything, the headlight assembly and the burners and then the voltage is different it starts out real low then gets higher it would cost around 4 grand. How much better will this kit look? although R34's have xenon as standard or option coz everyone i've seen up close hase xenon written inside, but not all have the blue tinge. correct me if i'm rong (which i think i am on a lot of things)
Guys sorry for the late reply but ive been bogged down with work etc
Ill give you his email, and directly pay him through paypal or wire transfer etc, for the above price :D
Just say your from the group buy organised by tim
His name is
ronal ma
[email protected]
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
