Hey,
Needed to replace my engine fan due to larger radiator.
Went down the thermo-fan path and now need a controller!
I am after a thermo fan controller which reads water temp sensor (better to get another water temp sensor), can define a turn-on temperature (85degrees) and turns off when reaches another temperature (80degrees)
and turns on constantly when AC is on.
What is the best option to do this?
I have found;
http://www.spalusa.com/store/main.aspx?p=i...item=FAN-PWM-V3 but they want $160usd for it O_o
Thanks for the help
https://www.sau.com.au/forums/topic/323396-thermo-fan-controller/
Drift have a pretty nice looking fan controller & at a very reasonable price...
Haven't used one myself but have heard good things about them. Check it out on their website.
As for the a/c side of things I think you're on the right track. May need a 5-pin relay with two switch points, one for fan controller, one for a/c...
Cant find an instruction manual for it. The site doesnt say much about its functions which is a pain.
i have a hks fan controller, comes with loom etc, it gives in-car temp reading etc, never used, u just need to download the user manual and ur good to go
exactly like this
http://www.frsport.com/HKS-Universal-Elect...ller_p_875.html
120 bucks delivered anywhere in aus u may be :)
exactly like this
Hey,
Thanks for that, let me do some reading up on it to see if it can do what I am after.
Ill try and find a user manual.
Cheers
Thanks for the links Trent.
Cant find user manual for the Drift controller so unsure how it exactly works. Im leaning towards the Spal thermo controller which can control two fans independently and loads them up gradually from 50% to 100% if temperature increases. Stops two thermos turning on at 100% and draining my car of electricity haha.
Looking into fitting an AU thermo shroud as many have done in the past. If it doesnt fit, ill go down the path of your flex-a-lite low profiles.
Oh how i wish you still did mechanical work ;)
on another note (if you see this reply);
had to replace the gtr injectors 440cc with 550cc due to leaks!. Is there a way I can limp the car down to your place for a tune?
Cheers
sounds like an easy job for a small microcontroller and a relay/thyristor... could even run it on PWM using a thyristor to keep a more constant temp.
haha well you seem to know whats going on. Make one up and earn some quick cash :(
Maybe i should. wonder if anyone else would want one.
The first one would be a very rough prototype, if i was to make one. Not too pretty to look at...
I'll have a look at water temp sensors, do ya know where the stock one is located?
this is where it is for the r32, not sure on any other model skyline
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
