Hey guys,
I don't really know where to post this question as it doesn't really have much to do with the Skyline itself so I apologise in advance, but I'm just wondering whether the APEXi Power FC for the RB25DET is really discontinued or not. The reason I'm asking is because I am really confused how a product which have been proclaimed by everybody, and even tuners who I recently contacted, to be discontinued could be popping up on sites such as Nengun and eBay as brand new. I have asked one of the seller on eBay and he said to me that they actually still do make it albeit in limited numbers and only to certain distributors. Is this true? I don't want to believe him only to find that it's actually a replica of the original.
Anyway, I apologise if this have been answered or cleared up before but I have tried to research both on the internet and the forum, but ever since 2006-2007ish when everyone said that it had been discontinued, I can't find much update or information on them.
Once again, sorry if it's a bit off topic but I'm currently on the market for a PFC and just need this to be cleared up before I make any purchase :S
Thanks guys,
Rian
https://www.sau.com.au/forums/topic/323479-apexi-power-fc/
They don't make them anymore, don't listen to ebay sellers. They have started making a new version of it, which is what Nengun sells, and you will probably find that the ebay ones are either not brand new or the seller has had them sitting for quite a long time which isn't unlikely.
But why do you want to buy brand new? Bloody expensive brand new, you might as well get a ViPEC for a better price. Scope out the for sale sections, much better prices second hand. For example: http://www.skylinesaustralia.com/forums/Ap...33-t323468.html
https://www.sau.com.au/forums/topic/323479-apexi-power-fc/#findComment-5273039
The only reason I wanted to buy a brand new one was because for the few days that I have been looking around, the majority of them are selling for $1200-$1500 second hand, which is not that far off from the price of a brand new one on eBay. So why wouldn't you consider buying a new.
But damn man. Thanks for that link. You quite literrally saved me a shitload of dosh! I am assuming that if I was to get it proffessionally tuned, I don't need the hand controller?
Thankk youu veryy muchos!!
https://www.sau.com.au/forums/topic/323479-apexi-power-fc/#findComment-5273054
You're still lucky man... u can get stuff used from other guys there!
Right now i'm looking for a pfc for the 25 as well and my only options are from ebay aus which sucks because i'm on the other side of the globe.....Ive been hunting in the usa but with no luck
There are not many options here at all and stuff that are available.........well i shouldn't say available, but could be ordered through authorized dealers here are exp like shit and they dont even tune them.....
An eg is the vipec pnp which works out to about $4500 aus and thats without tuning!
Ultimately i want the pfc because i will be doing the tune for myself and this looks like the easiest to tune by far plus i like the use of the hc to monitor but i'm really
frustrated now and it looks like i might have to go in the direction of the emanage ultimate instead which looks confusing as hell for a novice like myself!
Ive read Trent (Status) emu thread probably about 3 times now and from those who are using it seems to have issues to iron out still
So are there any well known sau traders willing to hook me up with a 25 pfc..... It MUST be tested and in good working condition tho because i dont want to fork out for it and ship it to the Caribbean and then end up with probs......
Dont know if i can trust the ones i saw on ebay aus. with the "no warranty on electronics" thing!
Any advice?
https://www.sau.com.au/forums/topic/323479-apexi-power-fc/#findComment-5273149
Can u give me more info???
As i said i'm not in aus.
Thanks
You can buy a plug in Link (a ViPec is a rebadged Link) straight from the factory in New Zealand for about NZ$2000:
http://www.linkecu.com/
or there are US distributors:
http://www.linkecu.com/dealers/dealersusa
Oh OK I see you are not in the US - well just get one from NZ and get the tuning software as well and tune it with a laptop - assuming you have all the gear - wideband afr meter, ex temp guage, etc etc ...dyno?
https://www.sau.com.au/forums/topic/323479-apexi-power-fc/#findComment-5275795
some models are still made, some are discontinued
ECR33 is the most common problem one, discontinued as NEC no longer make the NEC PF74 (or FP74 cant remember) processor needed for it
ap engineering units are no longer made
pro versions are no longer made - these were made by ap engineering
BCNR33 / BNR32 / BNR34 / EVO / WRX etc units are still avaiable new from apexi
so yes they are still made new (some models)
for discontinued models (such as ECR33) you have to resort to 2nd hand units
https://www.sau.com.au/forums/topic/323479-apexi-power-fc/#findComment-5275802
ok that's a new one i havent seen
this is a special kit made by nengun directly and it includes
BCNR33 Powerfc
Field one touch loom patch kit
apexi rsm
map sensor + sensor harness
djetro sensor harness
air temp sensor
base tune for ECR33 djetro
all in a compete kit for $1960 delivered it looks like
i suspect the loom kit theyve used pairs up the map sensor input and also performs the other wire changes that cubes identified are required to make BCNR33 PFC work on ECR33.
https://www.sau.com.au/forums/topic/323479-apexi-power-fc/#findComment-5276075
yeah its a GTR R33 PowerFC, it has always worked on ECR33
the Mafia did it and cubes did it as well
you need to make some wiring loom changes (i suspect the field one touch loom kit theyve used does this) and some tune changes
the known gotchas we found was
if you DATA INIT- it will go back to BCNR33 defaults instead of ECR33 tune, so what happens here?
no support for VCT - sluggish car overall
bonus support for air temp sensor included
it will be interesting to see if the nengun/apexi actually remap the BCNR33 PFC or just supply a generic one
if its remapped properly (ap engineering stlye) then when you DATA INIT, it will come back as ECR33 Djetro and also VCT would be included if they remap it properly
https://www.sau.com.au/forums/topic/323479-apexi-power-fc/#findComment-5276670
no idea, it doesn't say
so the unknowns at this stage
why is the RSM included
is it a Ap engineering style remap (ie permenant remap, so DATA INIT is OK)
or is it a BCNR33 with a custom tune (ie DATA INIT will revert back to BCNR33 defaults)
does ETC VERSION show RB26DETT or RB25D1 / RB25DETD1
is RB25DET VCT supported
https://www.sau.com.au/forums/topic/323479-apexi-power-fc/#findComment-5276748
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
