hey can get 264 and 264 with 9.5 for $850 brand new. looking for somethings cheaper second hand possibly.
thanks anyways
Those ones on ebay are $890 delivered and for an RB26 not 25. Plus they are Procams not Poncams.
Try and buy the cams and valve springs to suit for $1000.
So my offer is very reasonable.
https://www.sau.com.au/forums/topic/323609-cams/#findComment-5276494
yes PRO cams worth more than pan cams. also 26 will go into 25 :) and th pon cam is on there for 829. but fair call if they come with spring. i miss read it and thought you could throw them in for extra. f*k knows how i got that lol
but yeah only need cams. not any need for springs unless i go over 9.5 lift
how much would you do just cams?
https://www.sau.com.au/forums/topic/323609-cams/#findComment-5276625
  • 2 months later...
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
