  • Replies 205
Firstly, LOL at pretty much all the posts since my last
But secondly, i now understand how to play caravan, but still dont understand why you can wage 5000 caps and when u win u only get about 240 :S
anyone able to explain this?
i never said you was gay.. and wut gf.. i never mentioned gf
yea you did, in the screenshot....
and yea you did mention my gf, before you edited your post and changed to my mum....
craig, your a fat jerk
Yeah, cause the AI player only bets a certain amount, even if you raid it 5k.. Do you do the 7, 9 & 10 trick?
WOAH....WOAH....WOAH.....WOAH......WOAH BACK UP ONE SEC!
There is some sort of download shit on the PS3 that lets you continue playing Fallout 3 after the finish of the game?!?!??!!?
Yeah there are 5 add-on packs.. at least for Xbox & PC..
Point Lookout - A whole new island you get on a boat and takes you there
Mothership Zeta - Invesigate aliens
Operation Anchorage - Takes you back in a Virtual Machine to a war, also end rebroad minded person of that opens a door with awesome armour and a sword
Into The Pitt - Travel to Pittsburgh
Broken Steel - Extends the game after you die, you wake up instead and join the brotherhood of steel to finish of the enclave
Bonus with Broken steel is that it raises max level to 30.. Even if you start the game again
I traded my FO3 in for the Game of the Year edition.. Which includes all 5 add-ons..
Did you buy it or did you aquire it?
Shit Computer is shit
bought it
i run it at ultra graphics with no bloom or hdr and a couple of other things, and it runs just as slow on the lowest settings...
its playable but, yea just buggy and non consistent fps is annoying
stop using XP then you shitkunt lol.
runs fine with everything turned up for me w/ 4x AA and AF on ultra high quality settings.
that said it still has memory leaks ffs
Yeah, takes some time with 6GB RAM though
You can't run ultra graphics in XP, it's not an option.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
