whos smart ass? he got good ts? mayb u dont change gears quick enuf?
Yeah I have a lot of work to do and a car I can grow in to. More capable than my current driving skills. Yes my gear changing is crap. Who drove it well I wont really tell needless to say has a lot of experience and has driven 9sec cars. This is only the second time I have ever drag raced and am happy to be in the 12s. Anyway was keen to see any footage. The car was getting quite loose in third towards the end of the track.
Actually 0.4sec is a reasonable difference (as is 5mph) On the drag strip a 12.4 vs 12.8 (assuming even launch) is a multiple car gap. On the road it won't make as much difference, 'cause a 12.4 & a 12.8 will still see you defected just as fast :P
Judging by the lastest AIR results from Greg's & Lachlan's cars they couldn't be more evenly matched! Providing they're the ones doing the driving :)
Drag racing is so much fun. Great to see you guys out there that night.
Your cars looked excellent. There are a lot of V8s on the street that dont pull those times.
Well done. As far as Micks driving is concerned, yes he is a good driver.
Next time why dont you guys swap cars for one run. It amazing how much faster a car can go when you dont own it. ha ha.
Must admit I am a little hooked. Think I will be away for the next one however. Decided to get some nittos and rims for racing. Save chewing up my 265 18 inch RE540s. If anyone knows of some for sale I am interested.
Yep it was fun, pretty steep learnign curve. Especially when we started out in the mid thirteens and ended up with the times we got.
Joel, spool up is not THAT much different between motors, I have stock exh manifold, plenum etc that might help with spool up as my compressor and turbne wheels are bigger than Grepin's but he has Greddy plenum, tubular exh and other nice high flowing stuff.
Might end up doing that swap Munro.........can you do no clutch flat gear changes with those gearboxes :)
Grepin was slack and did not organise his own cameras!! So no one has anything?
Greg,
        No muckin' around mate, straight for the Nittos! You sure are hooked! :)
Lach,
        Do you reckon Greg will lend us the Nittos? Just to keep things on a level playing field :spank:
Yeah mate, we'll teach him how to use them.....it'll be a double Garrett + Microtech Boost Worx vs HKS + PFC Tilbrooks WHIPPIN!!!!
Haha :) I guess it's only fair that Steve join in as the 2nd Tilbrooks/HKS/PFC car :spank: Hmmm.... how do you take timing out of a PFC via the handset? :P
OT - Go the Aussies in the cricket tonight! B. Lee you legend!
You can add or take timing out using the HC.
Also add or reduce fuel as well. Does it across the whole map. Used the fuel correction when I fixed my leak and the tune leaned out. Good utility I can put in some Toluene and dial in a couple of degrees or alternatively add boost and take some out. Not as good as having different maps like the Mocrotech however. Anyway Datalogit is now available for GTSt. Will be mine shortly.
Great game of cricket!! No way the enemy will get a hold of the nittos. May already have some rims lined up. Better have a look at the SAU drag times to find where the HKS vs Garett vs Tilbrooks vs Boostworks vs ...........sorry nodded off. Boostworks needs to find a driver to compete in the tuning shop driver category.
;) nice times guys .... all you need now is to crack 12.74 and you'll be in the game :) :) :) j/k .... I very much hope you guys will be running at the 4,6 and Rotor Nationals 14th Feb!!! I will be and I don't want to be the only street driven jackass out there.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
