Any clues?
I had 4 new tires fitted (and balanced) along with a 4 wheel alignment but the problems haven't gone away.
Occasionally under brakes I will get a very bad steering shake. I thought this may have been due to warped discs but seeing as it happens erratically I'm thinking worn ball joints/tie rods/bushes.
Does this sound right?
And prior to the tires/alignment my car was pulling right. My steering wheel was about 10 degrees off center when driving in a straight line. Post tires and alignment I still have this problem.
I would've thought it was a cock-up by the guy who did the alignment but I can't help but think it's either a chassis alignment issue (I think my car has been pranged at some stage) or the front tie rods, ball joints and bushes are cactus.
If anyone is able to give me some direction that would be greatly appreciated. I'm not sure where to start.
BTW, car is S1 R33 GTST with 17x7 front 7x8 rear and 235/45s all round. Sits around 2 inches lower than stock.
https://www.sau.com.au/forums/topic/324540-4-new-tires-4-wheel-alignment/
The suspension place should have advised you of any issues. I went to Traction tyres Rowville with a slight pull to the left, mainly under braking.
They made a small castor adjustment (aftermarket castor bushes) and its now perfect, they also checked everything else out to make sure its ok.
Sorry I can't help anymore.
Sounds like you had a wheel alignment at the tyre shop, that was a mistake. Take the car to a proper suspension shop if you don't have the knowledge to sort it out yourself.
I would suggest Fulcrum as I don't know of any other reputable places in victoria. If you were in Brisbane, I'd say come and see me.
Hmmm....
Maybe I'll try and track down a suspension joint.
Anyone care to recommend someone in the North East or Eastern Suburbs (ie. Greensborough area or Burwod area)?
Hmmm....
Centreline in Thomastown. They are an SAU sponsor too
If its shudder under braking, it sounds like warped rotors. Same thing happened to me a while ago until they got machined. One of the best things I ever did. Now they squeal like a bitch though lol. Can't win!
That's what I originally thought. I've moved away from that a little as the shudder is not consistent. I haven't ruled it out however.
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
