Ok guys,
I know my car doesn't have airbags (least i think i know)...
there's no room...
1992 R32 GTS-t...
The drivers side flip down sun visor thingy has a labe that says SRS airbags... (could have been replaced easy)...
but at the front there is (what looks to be) 2 airbag sensors......
I thought it was an ambient sensor but there's 2 and they look like airbag sensors????....
can someone maybee post a pic of what the front should look like?
cheers,
Dave.
https://www.sau.com.au/forums/topic/32477-can-some-one-explain/
The airbag was optional on the later R32 GTR's, unsure about GTSt's. But mines a 1992 model and has the same visor, so I guess Nissan were planning on putting airbags in so just used one generic sunvisor with the srs warning on it to save costs.
The sensor wouldn't be in the visor - or are you talking about the dash?
If your car has airbags it will have an SRS warning light in the instrument cluster, just like all cars with ABS have an ABS warning light. But I'd say the visor would have been replaced as part of compliance, because jap visors are apparently dangerous and ours have much better levels of cushioning.
Don't go crashing your car to test if it has airbags now will you ;)
I've never heard of a visor being replaced for compliance, I'll have to take your word on that one ;)
*It could also be that every car gets the same visor - with the same printing, regardless of what it is optioned with
* whether it is legal or not, the japanese *seem* far less worried about ditching a factory airbag wheel
* it may be possible to work out what it was optioned with, by checking the #'s (tyre placard area? not sure, that's where it is on my rx7, never checked on the skyline) - I had a full list of option codes but I gave the magazine away to my brother-in-law - maybe it's been posted here before by someone
mine has the same label on the drivers side visor (all jap writing with SRS airbag being only in english)... it is a 93 R32 gtst. if it was put on during compliance it probably would have been an aussie visor hence there would be no jap writing on it, so my guess is it came out factory and nissan stuffed up..
not too sure what that chip/sensor thing that is on the dash near bottom of the windscreen on the passenger side. i have asked the question before on here and nobody could tell me....
my visor is the same
its a "sun sensor" for the climate control
my guess is it came from factory with the sticker and wud read on the label something along the lines of...." If vehicle fitted with srs airbag then....." dont know jap but wud be nice if sum1 can confirm my theory.
cauz they cant really guess how many cars will have air bag, therefore how are they suppose to know how much visors to manufacture ???
easier for factory to build all the same and put a sticker on.
what do u guyz reckon ???
Ok guys,
cheers,
Dave.
what about this bit in particular... the sun visor isn't such a big problem because as someone said it may say "if this vehicle is fitted with an SRS airbag...".....
I am more curious about the 2 airbag sensor lookie things behind the front bumper.....
Mines a 92 Type m and it doesnt have an airbag but does have the warning label. So it is safe to assume that all cars have the warning label, even if they dont have airbags.
What sensors are you talking about?
Whilst we are at it, can someone translate the other side, the vit about the exhaust temperature warning light?
airbags do not go off on externally mounted sensors.....they are triggered by either the seat belt storks being stretched or the belt itself.....there is also a seneor/module unit that sits underthe consol....thats all...no parts outside the car
I got a 1993 GTS and it has the airbag warnings too... and just recently I've found out that it was a GTS VSpec 2 (yes it exists my dealer warranty from japan says it to so its proof enough), which comes with a factory GTR steering wheel, so I dunno if it has or ever had a airbag in it.
But the sensor next to the windscreen is a climate control sensor... how do I know... well I took the dash off n forgot to plug it in and all my car did was blow hot air.
if u wanna no if it has airbags, just turn on tha car (without crnaking it) so that your dash lights up like a xmas tree...if it has airbags, there will be a SRS light, just like ABS, Hicas, 4Wd, oil, etc)
dont know abt those sensors, unless they were a parking sensor type gimick in japan, and tha previous owner took out tha in cabin control module, but i dont know why they would bother removing it.
Typo...
There was a GTS25t Type M "Spec I" and a GTS25t Type M "Spec II"... no GTS25t V-Spec Funky, sorry.
ooo ooo ooo for once you're not right and I'mma gonna enjoy this moment rezz ol pal :devil:
I just happened to have this in my glovebox in my car when I go it... scanned in a few low res scans for you... oh look it says GTS V Selection 2 :D
anyways, back to the revelling... :Owned: :(:):D :D
    • If you have a RB25DET NEO AWD motor, you will need this: https://www.hioctanedirect.com/ASR-RB26-RWD-Street-Comp-6.5L-Sump-Suit-R32/33/34-and-VL It is made for the AWD motor, but makes it fit a RWD setup and gives you a new pickup. Just one thing, the pickup sits quite forward, compared to a conventional RB25DET RWD motor. This may or may not have contributed to my previous AWD -> RWD shitting the bed at the track.
    • My car is also flex tuned. It's worth mentioning it (the LS1 ECU) has a 1D table for E85 addition and just uses the ethanol stoich part as the second point of reference. It also as a 3D timing map for Ethanol adjustment. You would think this isn't enough but it works pretty damn well. That said, I wouldn't want it in turbo application. It's like lifting non-natty, or taking meth. It gets you unrealistic results that break down more things going forward. If people used it to make the same amount of power they do on 98 then it'd be one thing. But people use it, crank it up to eleventy million PSI, it doesn't knock - but it pushes the point of failure to another, more expensive thing to break. Every time I see someone make 280kw on 98 and 350kw on E85 on the same equipment I just cry a bit and really wish they would just stay on 98 in that exact scenario. It's bad for you.
    • This is kind of what I was thinking but the temp sender wire and the two pressure switch wires run through the starter subharnes and I eliminated the two pressure switch wires completely.  @GTSBoy I have a can gauge with unusually bright warnings should the oil pressure fall so the factory light isn't needed. I need to dig out my wiring diagram and see if I can sort this out.
    • It's a valid point. And it is doable with the Nistune. But I'm not inclined to flex it the way Nistune does - certainly not on a Neo ECU. They're already pernickety enough to tune just one one fuel. And of course, I'm not that interested in putting in a Link or similar, on a daily. With the stock ECU, stock looking turbo, etc etc, I still stand a chance of surviving a run-in with the plod. Last time it went over the pits (which was for the transplant, for because of a run-in with the plod), the Nistuned ECU did not even raise an eyebrow. They want to see a stock ECU running the engine, and they are happy to see it do so without the check engine light** on. Never mind that the Nistune is necessary to make the stock ECU work in a different chassis without ABS, TCS, etc. **And they actually provoke the CEL to come on by disconnecting the AFM, to prove that the globe hasn't been pulled!
    • This is why you flex fuel it...
