What you got?
thanks
What clutch are you using it for?
I tried using an OS Giken one from my old OS clutch with my new NPC clutch and it didn't work. Ended up swapping the parts over to turn my gearbox into a push type.
i got a nismo twin plate clutch which is pull. Gearbox is push off a 32 gtr - you think this could be a problem?
Cheers
You need to run a Pull type set up to suit your clutch.
Buy an OEM pull slave cylinder, front cover assembly with fork, gaskets, bearings (14mm for twin or 24mm for single plate) etc then drill and tap the bosses and swap them over..
I got mine from Just Jap, was about $160 all up.
http://justjap.com/store/product.php?produ...at=0&page=1
Cheers
Johno
Cheers
Johno
Yep that's what I did. Not too hard to do. As I said sometimes the converter doesn't work.
Link here on how to do it: Pull to Push Conversion
