GETSET Posted June 14, 2010 Share Posted June 14, 2010 What you got? thanks Link to comment https://www.sau.com.au/forums/topic/324806-pull-to-push-kit-for-clutch/ Share on other sites More sharing options...
Deano45 Posted June 14, 2010 Share Posted June 14, 2010 What you got?thanks What clutch are you using it for? I tried using an OS Giken one from my old OS clutch with my new NPC clutch and it didn't work. Ended up swapping the parts over to turn my gearbox into a push type. Link to comment https://www.sau.com.au/forums/topic/324806-pull-to-push-kit-for-clutch/#findComment-5292094 Share on other sites More sharing options...
GETSET Posted June 14, 2010 Author Share Posted June 14, 2010 What clutch are you using it for?I tried using an OS Giken one from my old OS clutch with my new NPC clutch and it didn't work. Ended up swapping the parts over to turn my gearbox into a push type. i got a nismo twin plate clutch which is pull. Gearbox is push off a 32 gtr - you think this could be a problem? Cheers Link to comment https://www.sau.com.au/forums/topic/324806-pull-to-push-kit-for-clutch/#findComment-5293023 Share on other sites More sharing options...
J'z-R33 Posted June 15, 2010 Share Posted June 15, 2010 You need to run a Pull type set up to suit your clutch. Buy an OEM pull slave cylinder, front cover assembly with fork, gaskets, bearings (14mm for twin or 24mm for single plate) etc then drill and tap the bosses and swap them over.. I got mine from Just Jap, was about $160 all up. http://justjap.com/store/product.php?produ...at=0&page=1 Cheers Johno Link to comment https://www.sau.com.au/forums/topic/324806-pull-to-push-kit-for-clutch/#findComment-5293156 Share on other sites More sharing options...
Deano45 Posted June 15, 2010 Share Posted June 15, 2010 You need to run a Pull type set up to suit your clutch.Buy an OEM pull slave cylinder, front cover assembly with fork, gaskets, bearings (14mm for twin or 24mm for single plate) etc then drill and tap the bosses and swap them over.. I got mine from Just Jap, was about $160 all up. http://justjap.com/store/product.php?produ...at=0&page=1 Cheers Johno Yep that's what I did. Not too hard to do. As I said sometimes the converter doesn't work. Link here on how to do it: Pull to Push Conversion Link to comment https://www.sau.com.au/forums/topic/324806-pull-to-push-kit-for-clutch/#findComment-5293691 Share on other sites More sharing options...
