  • Replies 52
Interesting... Arent we currently talking in the 140kmph thread about how most drivers are under educated? By saying 'I only had this much practice and I passed' probably just makes people find it ok to practice less because other people have and have gotten away with it. This is most likely the mentality that increases collisions caused by inexperience. Not that I'm saying a person like that would be a bad driver, I only had four classes (min avail at the time) and passed fine, but I'd been driving paddock bombs for about 10 years before that :P
I also recommend getting your car in someones paddock and just let rip... it always helps me remind myself of how a car reacts when you loose traction, and that's something they can't teach. Plus grass can be nice and slippery :)
Wish i had a paddock to fool around in. I had an army bombing ground though, but all the stupid shit was done using a fwd 1.6Turbo fiat bravo. After awhile, you run out of shit to do. =(
I was in Queensland for 6months and booked my test without doing any lessons.
It was a long shot because they were just implementing the 2008 July 1st Law. So it was do or die i wasn't going to not try.
So did you pass or not?? The only thing you have to do is not panic, go in thinking your a skilled D1 driver who conquers the road, worked for me.
ps. i didn't lose any points. like someone else said, a monkey can do that test. the only thing my awesome tester told me was; "you take corners a little fast".
Passed the test, parked the car, told him i never did a lesson and he said god help you. Hahaha
My twin went for her license last month and passed, I was shocked. She crashed 3 days after getting it! She's not the best driver, and she'd never had any parking practice prior to her driving lesson on the day before the test. just goes to show how easy it is. I go for mine next week so fingers crossed I'll pass.
Thanks alot guys you really helped out. i only f**ked up on a round about, forgot to indicate, and on ballarat road i didnt accelerate quick enough after doing a U turn. 2 critical errros total.
Funny story about a car. I was going to buy an r32 turbo, i think an rb20det, i gave the chick a couple hundred deposit after i looked at a few weeks back but after i left, another person came and test drove it..."apparently" the peson broke the car.
She says its the fuel pump or some shit so now she prob wont sell it to me because she is going to make that person buy it. I was so shattered when i rang her yesterday, it is the hottest r32 ive ever seen.
So i guess im in the market for a r32 or 33. :)
thanks again guys
edit: this is the car i was going to buy, you can see it says "on hold" which was meant for me :D
Beautiful R32
Edited by drive_guy
They didn't break the car, they offered her more for it than you did :)
Not a good looking R32 IMO you can do much better than a rat rod spec thing like that. Why don't you get something like a non-turbo R33 for your P plates...
Do yourself a favor and DO NOT buy a turbo i was about to buy a 32 GTST but went for a non turbo 33, so glad i did because a week after I got my 33 I had the car fully searched by TMU for shit, and that would of been bye bye right there, not to mention I've been pulled over around 15 times in the time that I've been on my Ps.
You've been pretty unlucky with cops.... 16+ times :)
And Just because you are getting off your P's and drive a turbo, it doesn't mean they won't puill you over another 15 times and defect you 15 times :D
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
    • I used to love going to Amaroo to watch the HQ series go for broke (eventually stopped due to lack of spare parts) and also the Porsche series.  It was so cool to back your car up to nearly the edge of the viewing barrier and party with your friends, having a bbq and alcoholic/non drinks. It was such a family/mates atmosphere
