GTRS's or large dash 10's is the way to go
Good power, good response (although there's a lot more to it than just turbo choice), stock looking, very good powerband of usable power
If I had my time again I'd go dash10's with the largest fans possible but that's just me
I was thinking about going T51R kai. As thats somewhere inbetween the T04Z and T51R SPL.
Is there that much of a difference between the KAI and SPL model? Should make more than 600rwhp with T51R kai if T04Z should get me there?
Cheers :P
im making 450rwkw on 23psi with my -10s.
if u want a street setup with good mid range response, go with -10s or hks gtrs (the hi octane gtr will give u a good idea of the ride)
if u want more power BUT also sacrifice 1000+rpm in delayed boost response, get the t51r.
t51r would be great on a 26/30 without a doubt :P
all depends on how you want it to come on.. or fall off between gears for that matter. why not try something like a borg warner? the 72mm s400sx3 would be a good start. and ALOT cheaper. and good for 70psi..... also proven to be more responsive than a gt4202
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
