Mine did that when the alternator was on its way out.
Otherwise open your boot look under your parcel shelf there will be a metal box off centre to the right hanging off the parcel shelf. Make sure it is connected. It is speed sensitive steering, which comes on at slow speeds to help with parking and slow maneuvres but turns off at higher speed.
Skylines have that? I thought that was a more modern feature..... makes sense but didnt know R32's had that....
Sounds like HiCAS... (which does have a little computer in your boot)
which he doesn't have?
and from every other source i have read, the HiCAS is only for high speed cornering not as a parking aid.
what i thought tomcio was talking about was something newer cars have which is as the car slows down the power steering gets lighter but when ur at highway speed the steering is a bit heavier so the steering isnt as twitchy etc
But yeah Im pretty sure skylines dont have that?
Anyways cant be hicas computer, or was hicas an option on GTS's? not sure about this
charging at 13.9 its still sweet, i has to be somthing electrical, it randomly goes easy, its like its stuck on high speed steering or somthing...i have a brown box under my shelf, no plug connected or any plugs near it too be connected, strange.... i find many plugs that are disconected that have no were too connect too on my car lol its really weird
Edited by 51NNA
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
