hi i have tryed to do a search but can only find info in the r33 models ,
so if you want to post and say do a search maybe back that up by directing me to the page that comes up in the search as i cant find it !!!.
no i have an r34 gtt series 2 and i dont like the front bar as its restrictive for the radiator and inter cooler and when i put a front mount on i wont get the full benifit . so i want to fit an r34 series 1 front bumper bar , iv read on another post (i searched for ) that on the r33 to do this you have to change the bonnet , headlights, front reo and front quarters , is this the same for the r34 ???
i do know ill have to change the indecaters but thats a given as there in diferent places and are totaly different lights,
if some one has already done this i would love to know how you went about it
thanks for your help
  • 3 months later...
hey i know this really isnt the place to post this but i cant get a straight answer of where i can find stock photos for a s1 and s2 gtt r34 2 door manual.
can anyone help me out?
hey mate my car is a 4 door so that wont help but im sure if you have a look through the garage section you will find some , ill have a look on google and see what i can find !! and post the link or photo for ya
only difference thats a put off on the series 2 is the bumper but after a bit off stuffing arround i managed to fit a blitz intercooler in and it hides rather well .
series 2 the interior plastics dont scrach as easy and seats steering wheel are two tone in colour .
i love my car and iv come to like the look with the s2 bumper as the police leave me alone
also swapping bumpers can be done but it involves removing or replacing front reo and the brackets under the head light (all costs alot )
so if you go series 2 keep in mind if you want to put a kit on it with new bumper your looking at $300 on top to get the series 1 reo and brackets to get it to all fit .
ah i see. hmm yeah i think i would prefer a s2, just because there newer and scratch proof and what not you know? hah
although i dont like the front bumper :D how much would it be for a different bumper similar or same to a 98?
isnt the spoiler different too?
im not sure about the rear as my 4 door only has a boot lip but you can pic up a series 1 bumper for anthing around $150 to $200 2nd hand
then you will need the front reo and headlight brackets ,
just make shure you get the car you choose checked by someone that knows skylines !!,
then enjoy it lol
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
