Just a quick note in light of Donor awareness week urging people to Register to become a Organ Donor.
http://www.medicareaustralia.gov.au/public...dr/register.jsp
Most importantly ensure your family know your wish's.
"Don't take your organs to heaven, heaven knows we need them here"
Being a organ donor recipient myself I know the importance or organ donation and was a organ donor before I needed an organ transplant.
Perhaps we can get legislation passed like some other countries where you can only get an organ if you were a organ donor prior.
All the best, and I hope more people register their interest.
Robert.
https://www.sau.com.au/forums/topic/325463-donor-awareness/
while not registered all the important people know that if the worst should happen every little bit of whats left goes to help those who are left
It don't matter because if you are not registered they cannot touch any part of your body for donation etc
that is why you no longer have the box on your drivers license to tick as family were contesting it
now you have to fill in all the correct paperwork to become a donor and you even get a card to carry in your wallet saying your an organ donor
https://www.sau.com.au/forums/topic/325463-donor-awareness/#findComment-5302166
I is a donor.
Exactly how much, if any, of whats left of me will be any use to anyone is kinda debatable, but if you can use it, and I am done with it, help yourself!
https://www.sau.com.au/forums/topic/325463-donor-awareness/#findComment-5303709
GOOD WORK PAUL & DALE ,HAVING BEEN CLOSE TO NEEDING KIDNEY`S AT YOUNG AGE,
EVERYONE SHOULD BE A DONOR REGARDLESS ,
THIS WAS ONE OF 1ST THING`S I DID WHEN I COME TO AUSTRALIA,NOT SURE IF THEY CAN USE THEM BUT YOU NEVER KNOW :(:banana::) ,
https://www.sau.com.au/forums/topic/325463-donor-awareness/#findComment-5303729
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
