Hey all.
Need a 14-15" laptop bag, must be able to fit a notebook or two, basic tech tools, HDD's without stretching.
Had no luck with Myer/DJ's/JB/Apple Store at chady today.
Needed this weekend.
Any ideas?
Toorak based.
-Ryan
https://www.sau.com.au/forums/topic/325527-best-range-of-laptop-bags/
Crumpler are the best bags I have found, to suit all different kinds of use. Awesome durability and design... They make notebook bags in all sizes and they don't look like notebook bags from the outside which is a plus.
try msy in box hill
thx, but they are flamin mongrels.
nice quality, but look like they are aimed at school kids.
mwave.com.au
pretty cheap but quality lappy bags. I've got a couple of belkin bags from there. Also Harris Tech does some cheap deals from time to time too.
thanks, but need something i can walk in and grab. will see it HT is open tomorrow.
Lol @ MSY. It's either MSY or CPL, which one is the lesser of two evils? :D I've found MSY generally to have much better customer service.
Fair call re Crumpler they have some outrageous designs I stick to the more conservative colourways.
Lol @ MSY. It's either MSY or CPL, which one is the lesser of two evils? :) I've found MSY generally to have much better customer service.
Scorptec for warranty/service!
wtf... warranty/service on a bag?
look it up on the internets, take your laptop in, jam it in when you get there, if it fits, buy it.
i meant in general....
Ended up back at Myer looking at Samsonite stuff, got a $230 one for $115. Best I could find to fit everything without going to a backpack style, or the bigger samsonite range that would be that bit big for day to day.
I get work to buy them and I love Targus backpacks. They're around $70-$140, but the quality is top notch. Very well made and rugged.
Find the model you want, then go to www.staticice.com.au and search on it. That will do the shopping around for you in a few seconds.
its funny you mention warranty on a laptop bag. they can actually be faulty :P in my experience have seen a few laptop bags be replaced within warranty (stitch faults etc). you never ever know!!
ever!!
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
