think north of $10k as a bare minimum to get it done properly. some spent $17-22k which is considered the norm for a well designed layout / install and tune.... e.g. APS kit
should have bought an R34 mate... :-) or M35 stagea... the turbos come 'free' in those... works out cheaper to swap
https://www.sau.com.au/forums/topic/325560-turbo-in-v35/#findComment-5301838
I already bought a v35. I love it. My folks helped me, and they thought R34's were too old. I'll buy one eventually...oh and a Ford Mustang with a blower...What? A guy can dream, can't he? I wonder if you could put a blower on a v35...with a hole in the hood, V35 Muscle/Tuner hybrid. Why oh why isn't there a pimp my ride in australia? Probably cause everything is banned in australia.
If there was, i'd just buy the body of a r34 and post a video to pimp my ride. Remake the whole thing. Fully sickness bro. More fuller then full.
Actually, come to think about it. I would buy the body of a nissan Gtr...I'll call up Jap World and ask.
Oh, btw...Brian from Just Cars...I don't have enough posts to reply to you yet, but you are f**king awesome!!! Peace
So, anyone else got anythoughts?
https://www.sau.com.au/forums/topic/325560-turbo-in-v35/#findComment-5302029
HKS does two kits, one is s/c and the other is tt kit... they're about $7-10k parts only ex japan not including install & tuning... if you can find someone to tune the supplied piggy back / replacement ECU.
APS have around $17k drive in drive out tt solution. Oh and if yours is 5sp auto you'll need have the auto rebuild
locally to withstand 500HP which is not included in APS' package. You see it will never be cheap to do FI on this car,
so best to leave it alone as N/A unless you are fully loaded with cash and got nothing better to do with them.
every country has their own different rule, unfortunately they can't just change the law for the sake of a bunch of 'pimp my ride' fans who felt left out. if you can't stand it, maybe take up a course/degree in teaching, and apply for an english teaching job in Japan and live there. car mod scene is more relaxed there... although they do still have 3-yearly road inspection called the 'shaken' which means they do still have some limits on how you modify your car before it's deemed unroadworthy and cannot be registered...
bye
https://www.sau.com.au/forums/topic/325560-turbo-in-v35/#findComment-5302072
When I was mucking around with mine I did consider a VQ30DET conversion. Decided to not go that way at the time, however, think it would be worth considering in future. Can pick up VQ30DET's for under $2000. Would have to look at sensor compatability......
https://www.sau.com.au/forums/topic/325560-turbo-in-v35/#findComment-5302117
Can't see why not given it is essentially the same block as the VQ. Aftermarket Engine management would be required but to purchase a VR you'd pay more than the market value of the V35 for a front cut
Edited by mosoto
https://www.sau.com.au/forums/topic/325560-turbo-in-v35/#findComment-5302223
I was considering doing this to a v36.
I use my V35 for work and it works well because its a sedan w/ CVT and just a plain good ride.
The reason i was going to go for the 36 is cause its got more powahhh to start of with and id be getting the manual coupe. No really point in having two of the same car either.
Spoke to a few people and the general concensus is that you'd be looking at about 20k to get it done right.
This includes: the kit, ecu, exhaust, cant remember if they incl brakes, and proper tune.
To me this would be AWESOME!
Since I do use cars for work i can claims stuff of tax, so I'm going to chat to my accountant and see what we can and can't do.
But the way I see it, $60-70k for a car that would be very quick and fun, w/ the skyline name and tradition, without the stigma attached to the hotplates would be pretty cool.
and it would just be really different.
Which is always good.
Hope that helps!
Cheers,
Tony
https://www.sau.com.au/forums/topic/325560-turbo-in-v35/#findComment-5302281
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
