I wasnt going to tell you all...
  • Replies 173
yeah it is :D i could get an R33 GTR quite comfortably with the money im spending on the mini but i want something brand new which doesnt cost me an arm and a leg for insurance.
no its a mid 15 actually... and its a Supercharged mini u fool not a beetle
haha.. i was wondering why he said stuff about a beetle..
i dont think ur going to get flamed that bad.. coz after all, everyone wants a new car at some stage :D
/me pulls out flame thrower: f.ugly, slow , and boring.. but your money :D last time i couldn't stop laughing when somebody actually tried to drag me in a copperS.. hey it "seems fast" lets go drag that skyline.
i only got yellow stickered once in melb, and its hardly as if my car didn't stand out..
p.s. you could get something a *little* more manly...
lol if i was to say no i would lie but i have always wanted one as a fun car but really wanted one after seeing it in the flesh... im going to test drive one on friday... if it feels nice and drives well i will be getting one... wont happen for a few months tho.. maybe around march near my bday
around 45 drive away :D
might get about a 4k trade in on my daewoo if im lucky... will find out for sure when i talk to them this weekend.
the one i want has leather, xenons, electric sunroof and 17s
http://www.minigaragemelbourne.com.au
-the list of std features is fairly impressive... plus its BMW so the build quality is excellent.
i want a red one with white roof, mirrors and wheels with the black leather and red cloth interior.
Inark,
Are you going the "Works" upgrade.... I had one of these for half a day, preferred driving my old Clubman GT. The seating & driving position drove me nuts, the steering wheel reminded me of a mixture between dodgem cars & the school bus. Went pretty good for a daily runna-round nothing to exciting, but the handling... wow for a front wheel drive the thing was rails.. about the only thing I clearly remembered about the cooper s, that friggin handlig.. "excuse me whilst I go pull myself :D"
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
