i need a white front bar, left front headlight and indicators where can i get them frm? or if u do have any of these
one let me kno CHEERS! 0431762826..
Import Monster.
http://www.skylinesaustralia.com/forums/in...mp;s=&f=187
Aaron has a half cut of a R32 you could probably get all you want from there.
Import Monster Australia - Head office, auction pickup & shop:
Import Monster Pty. Ltd.
Factory 3, 6 Wigan Road
Bayswater VIC 3153
03 9008 0031
Did you hit something this time Johnny, if you need help let me know.
Thanks man yeahh bad news i actually did.. Aha
Last week driving droping ppl at home.. was drunk! :P
i was thinking in my head that the coil overs that u fit on for me will drive for me sober when i was drunk Lol!
Now if u can help me look for a front bar left head light, indiacators. I need a lower control arm but that i kno where to get so dw..
after i fixs the control arm i would need to get a w/a get it rolling again! then after i think i will need to put my car up onto ur hoist to c if i push the driveshaft into the engine.. Thanks pan for helping a niger out again alright cheers man ;p!
This guy said 450 front bar? head lights 175 each what do u rkon its a good price ??
Last week driving droping ppl at home.. was drunk! :angry:
Try calling Nissan and see what they say...
Sounds ok... Either way you gotta pay for your own stupidity. :P
See if you can do a group buy and if they knock down the price any further...
Sounds ok... Either way you gotta pay for your own stupidity. :cool:
Yeh very dumb! Ahaha
Nissan place isnt it goner be very pricie.. ?
As Ash said, sometimes the prices are ok but mostly ridiculous + they would probably have to order it.
But luckily the R32 GTR was an ADM car as well as a JDM, so parts are still available through Nissan.
I got my Brake Pads, Clutch Kit / Flywheel, Clutch Slave Cylinder, Nismo front bar (Panel beater did) from Nissan.
Just had to wait for shipment.
Who did you get the quotes from?
Again, see if you can bargain it down or ask them to do the best they can.
Nissan is remarkably good on pricing for some items actually.
Others they are terrible... Just ask the question.
As for drink driving... you idiot.
:D
Yea.. im just gona get it repaired! Mch cheaper because it's only a cut from the vent threw the top!
for a genuine bumper for a r32 gtr is 1k from just jap or not unless get the copy one which is 525!
So i might aswell keep my genuine one and get it repaired, front guard that's cut threw from the vent.. back guard a lil dint and side skirt dj panel charge me $1100.
P.s
Pan, i think it's should be okay, I no need to go to ur garage thanks alot anyway! Alright man
wait till i get all this crap out of the way, Me and you got a lil catch up cruise...that we need to go on Ahaaha
Catch yah. Take it easy ;p! cheers
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
