Try the bluebirds australia site. :D
OK sorry. Nice sleeper to annoy the wrx crew with some mods...and it's a nissan so doesn't have the idiotic boxer engine that sounds like a mower. Std handling is a bit doughy so give that a tweak and should be nice.
hey dude im telling ya now bluebirds are really good cars they handel well and have got the power ti beat a stock wrx also not much ppl know wat type of car it is so u can say its a sleeper insurance is pretty good (depending on your age and wat not)if u are looking at buying one i know a guy who is selling a great example for 15k pm me and give u his contact number and email
:cheers:
hey when i was looking for a new car i wanted a jap bluebird, but they cannot be imported under raws, whiteline do a suspension kit and you can do all the usual sr20 mods, apparently they have a pretty weak gearbox though. Pretty cool car, beat skylines without too much fuss. They have attesa but they are front wheel drive til traction lost then rears come in - not as much fun as rwd skyline.
So many misguided thoughts here, but I refuse to battle wits with those who are unarmed.
Fact: won't beat a stock man skyline as standard.
Fact: not as quick as the same years WRX but mostly due to handling.
Fact: very few with manual gearbox.
Fact: with SR20DET and the Attessa they are very responsive to mods.
Worth buying, then debadge :(
Well i own a nice one and i would put it up against a gts-t on a standing start no worries.The atessa is rear wheel drive until the front kicks in.ive had no dramas dumping it at 7000rpm spinning the rears for a split sec then fronts grab and sling shot outta there.does need the whiteline kit to really push it through corners as understeer is scary.Need any more info give us a yell
I looked at a couple at an import yard a while ago. Tried to convince my mate to get one cuz hes got kids and needs 4 doors. They are a great sleeper, really nice interior with all power options and you wouldnt get hassled at all. Just about all of them are auto though. Just bolt on your usual mods and youll suprise alot of people out there.
sorry r34gtt-r, i was led to believe they were front then back - but you should know seeing as you have one.
skyline geoff even though i own a skyline i would still back the stock bird against stock line - i remember seeing the standard 0-100 figures on an importer's web site and one of the reasons i wanted a bluebird was because it's quick, quicker than a skyline even :)
Naa keep spending all my money on the GTT.
Here is the best article on Bluebird ive found well worth the read!!!!!
http://www.autospeed.com/cms/A_0140/article.html
"As a family-based car with stealth performance the 4WD turbo Bluebird is virtually unbeatable. It features a cavernous boot, an inoffensive interior design and NVH levels that are in keeping with any other mid-sized sedan. It is extremely safe with excellent stability, ABS brakes, an abundance of useful power, and it also returns good fuel consumption."
The auto version that we tested unfortunately had a badly slipping trans, but from seat-of-the-pants experience we'd suggest the car to normally be a mid-8 second 0-100km/h car. However, its performance times have been quoted as 7.4 seconds for the 0-100 and 15.4 seconds over the quarter. Without the fluid coupling, the manual versions cut these times to highly respectable 6.2 and 14.5 seconds respectively (remember that's on Japanese grade fuel).
Meanwhile the 33 is quoted at flat 6 and having imported these things for a while, I'll go along with that. So if you have no mechanical sympathy then do your 7 grand launches and lunch you clutch and box for 6.2's if you can actually get a manual. The numbers speak for themselves.
Back on topic though, I like them, but they won't really bother a skyline too much until it gets wet. Crap that WRX's are even a stockie will eat me in a straight line in the wet, and I get wheelspin at 180 in fourth in the wet.
Suit myself? I generally do. No drags for me unless it involves the rolling start from the corner entering the straight. I don't mind, any straight throughout the lap of the track will do.
I'm actually pretty envious that you've got a manual. The only manuals I had were already sold so I had to be nice to them...dammit.
So you were importing them???.If so who was compliancing them as i might have one of your old cars.Ive been a bit wrong in my posts as my car has button clutch and boost upped.But while my gtt is either spinning the wheels off the line or not enough revs and waiting for boost my missus already in second gear, top end she gets wrecked tho as the bird has short power bands.
Ah, found it...
http://www.importforums.com/information.htm
This was the info I was going on in my assumption of the bluebird being slightly faster than skyline, 0-100 atleast (by a whopping 0.06 seconds!)
Admittedly Skylinegeoff your knowledge is very good, but in you're "battle of wit's against those unarmed", is knowledge/remembering things witty or just, knowledge? Not wit by the definition I know gunslinger, but I have been known to propagate misinformed sh!t - just see above!
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
