I've got a rebuilt rb25det with a gcg highflow etc, currently it just has stock injectors/reg new pump and is running 10psi. Tuner said it is ok on the stock injectors and making about 200kw, anymore though and I risk leaning it out due to 100% duty cycle esp in cold weather or if I get a boost spike.
I had a fuel rail with gtr injectors, magnaflow regulator etc in it initially but it had to pass a full roadworthy so I removed them and got it retuned. Anyway its all on the road and I'm itching for more power, will be getting a Z32 afm and putting the rail and injectors back in, but I am unsure what to do about the regulator. I've read everywhere that the stock one is good for up to 300kw and theres no reason to change it, but being as I already have the reg are there any advantages to using it, or is it just going to make it harder for the tuner to tune? Will be putting the turbo up to 14-16psi depending on how it responds.
The other thing is its shiny and pink so it really screams defect me, so if I put it back in I'm going to paint it black along with the ultra shiny fuel rail to keep it looking stock.
Cheers.
:P
Edited by Rolls
keep the stock reg if it works fine. if you somehow max the gtr injectors way short of your power goals (unlikely) then, and only then, should you consider an adjustable reg
So theres actually disadvantages to the aftermarket reg? What are the differences, just the fact that it is adjustable and you can easily bump the pressure up? Or does the fuel pressure rise differently to a stock one, eg exponentially instead of proportionally?
Sounds like theres no good reason to use it so I will most likely adapt the stock one back on and sell it then.
rising rate regs rise exponentially, normal adjustable ones just let you adjust the base pressure. not sure about the magnaflow but most aftermarket regs simply arent as good as the standard one and also a waste of money/illegal if you dont need it.
Thanks that is all I needed to hear, I will adapt the standard one onto my aftermarket rail. Wasn't sure if the stock ones were a proportional rise or exponential, if they are prop then there would be a definite tuning disadvantage with the aftermarket exponential one.
Depends... some regs don't work all that well.
There are a few nasty experiences with Malpassi (as an example) across my mates so ye... where possible i'd personally stick with stock.
+1 to confirm rising rate is important, stock is rising rate.
Can you confirm what motor you are running? You said RB25DET and GTR injectors... Unless its an R34 NEO can you please explain your use of GTR injectors?
Cheers.
Series 2 rb25det rebuilt with forged pistons etc. Has series 1 running gear and some rb20 stuff as it is in an R32 gts-t. Turbo is rb20 but highflowed by gcg so it is basically identical to a 25 highflow hence the need for GTR injectors.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
