Hey guys,
im just curious for those that have travelled to Japan/ Lived there - what is the general japanese opinion on the R33 GTS-t? it's common knowledge that S13/14/15 R32's are very popular for drift, but what do the Japanese think of the R33 Gts-t? do they get used commonly for drifting/dragging applications? or are they more the commodore commuter equavilent...
https://www.sau.com.au/forums/topic/325749-r33-gts-ts-in-japan/
Damn good question. Ill send this Q on to some friends of mine in Japan n see if they can comment.
Id go for saying that they were like the Monaro in Aus. In most peoples eyes damn good, damn popular, commonish but still make people look, and of course there is always the bigger badder GTS that gets the bragging rights- just like the GTR-GTST
unable to get any extensive comment from peeps, only that it isnt used for drift due to its wheel-base n weight, especially when there were so many other cars out there that are better and cheaper for drifting purposes- eg. sr20det line-up
TBH a lot of them think they are an old car, hard to fit in a pay parking bay because they are a bit long compare to other square cars they've got atm. I actually saw more GTRs than GTS-T when I was there last trip. There aren't that many R33 on the road in Japan :P (compare to Australia)
given that there are so many here there prob isnt as many in J land. Also GT-R's are the price of gts-t's almost in japan so why would you buy a gts-t
I was gonna say, for most people these days, R33s are irrelevant - they're old cars, too old to be of interest to the general public, but not old enough to be considered a classic.
Per capita, there are probably more Skylines in Australia than in Japan.
I would have thought at their peak they would have liked them, as for a while nearly every single R33 that appeared at the docks had an HKS pod and some sort of aftermarket exhaust on them.
Just like those AE101 Levins, it was hard to find one that didnt have the TRD or somethig similar bumper on them.
r33 hav a bulk body than the s12 etc thats 1 reason why they dont prefer r33s
I don't see many R33's owned by Japanese in Japan any more. But I will say that foreigners living in Japan seem to absolutely love them. I guess because they are slightly newer than the R32, reasonably priced, and easy to modify.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
