Hi guys,
I realise that 99.9% of you probably aren't interested in the R34 4 doors, so you can probably stop reading here. Anyway, if you're at all interested in them, here's a really good site that lists so many things I did not know about the sedan. I just thought I'd share this goldmine of info -
http://babelfish.altavista.com/babelfish/t...sedan/&lp=ja_en
There's some nice pics there too.
There's no coupe info there, so if it's not your thing, then don't bother looking :cheers:
Cheers,
Michael
BTW as an aside, does anyone know if the 25GT-X Turbo models have different badging on the back from the plain 25GTt? I haven't found any close up shots of one - only the 25GTt (maybe the GT-X turbo has the same sticker, so that's why I can't find a shot of a GT-X sticker).
https://www.sau.com.au/forums/topic/32591-r34-sedan-info/
  • Replies 51
Thanks, Dave
It certainly does look like it's a custom job. In fact, the 25GTt badge is down at the bottom. So I guess if that car is a GT-X Turbo, then that pic confirms that they come with the standard 25GTt badge. That makes my job a little harder to spot a GT-X to buy.
https://www.sau.com.au/forums/topic/32591-r34-sedan-info/#findComment-653173
Another excuse for me to post mine.
http://www.skylinesaustralia.com/forums/at...tachmentid=9415
I've already got rid of that ugly yellow number plate but I want to get clear indicator lenses although I haven't paid for my zorst (ordered from Japan though) or the Billsteins not yet ordered.
I think, seeing some of those that I might get rid of the wing. Opinions?
https://www.sau.com.au/forums/topic/32591-r34-sedan-info/#findComment-653212
GT-X does exist, its R34 GT-X which has RB25DE Neo engine with 4WD Atessa. 4Door.
My pick of cars have to be
Silver R34 GTT 4door
Impul R33 GTST Door RB25DET
Nismo R33 GTR 4d00r RB26DETT
The GT-X comes in NA 2WD, NA 4WD and 2WD turbo variants for the series 1 R34. They dropped the turbo variant of the GT-X for series 2 and changed the 25GTt a little.
https://www.sau.com.au/forums/topic/32591-r34-sedan-info/#findComment-653214
here's a late model GTT interior:
and what I believe to be a late model front bumper:
Some other changes:
The wheels on late model cars are slightly darker in color.
The interior has a lot of color-coordinated bits, the gear level and steering wheel, the centre console etc.
Engine wise, Nissan tweaked the Neo engine so late model cars have improved torque output.
There was another mechanical change too, but I can't recall what is was! :cheers:
https://www.sau.com.au/forums/topic/32591-r34-sedan-info/#findComment-653232
Yep, the 4 door silver one above is a 4 door R34 GTT, with after market panels added. It's also got the factory optional window tinting of the rear windows, and the 'wind guard' around the front windows..
ie it's the same car as I drive :-)
I'm not sure what the difference was between the GT-X Turbo, and the GTT, though most of the web sites I've seen ie
http://history.jbskyline.net/index5.php#10thgen
think that the X is the model down.
https://www.sau.com.au/forums/topic/32591-r34-sedan-info/#findComment-653250
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
