Hi all,
I just recently purchased an R32 GTR. Just fitted a boost gauge and noticed that it boosts up to around 20PSI. I'm not sure if there are stock turbo's in this car ... i know at 20PSI, it is no good for stock turbo's.. question is, how do i reduce the boost back to safer levels? say 12PSI?
Thanks!
https://www.sau.com.au/forums/topic/325931-r32-gtr-boosting-too-high/
at 20PSI this also no good for a stock engine (it will probably destroy it before long). i would start by finding the vacuum lines that come off the actuator on the turbos, make sure they are connected properly and follow them back looking for a split or a leak. or if someones fitted a boost tap you might find that somewhere along the lines. to reduce the boost pressure you first must find what has increased it.
if you cant work it out take it to a workshop (ideally one thats familiar with gtrs) they should be able to work it out pretty quickly.
right now you should assume it's stock standard as you dont know any different, so stay off the boost altogether until either a)its fixed. or b)you discover you have a built engine, aftermarket turbos and a tuned ecu.. lol
i'd like to think no one is wreckless enough to buy a gtr without asking the question "is it modified?" and get every detail if it is. neglecting this very simple step will result in you opening up a good ol' can of worms. i sort of made this mistake when i was 17 and it cost me dearly but we wont go into that.
only way really is to take off all the surrounding pipework to uncover them, if they are aftermarket they might have a brand name on the compressor cover, again probably a job for a tuning shop that knows their turbos and could positively identify them as there are some very minute external differences (if any) between a lot of turbos. if they are stock turbos that have been high flowed then it'll be even harder to tell. first thing i'd do is look at the compressor wheel, if its steel then its probably aftermarket. ceramic and it'll definately be stock, the ceramic ones dont like putting up with continued abuse.
No they dont! My R32 dropped the rear ceramic wheel a few months ago and the bits went back past the exhaust valves and destroyed my engine. You should see the scratches in the bores. Also if its still running the standard comp it will be having issues at that boost. its not the gauge is it. Can you borrow another one to double check?
I'd get it to a gtr experienced workshop asap. something is very wrong.
if they're stock turbos im surprised they're in one piece, if not stock and it has no other mods be very worried too!
fingers crossed its just a busted actuator hose, even so i'd be surprised if ur turbos or engine for that matter aren't damaged. :thumbsup:
sort of on the topic rb26 twin turbo setup the wastegate lever's attached to actuator rod with little CIRCLIP
any1 know a decent trick to getting them out without fkn around ... very tight spot
grow some ninja fingers. also use a small ultra fine flat blade screwdriver to flick it out maybe? and for the love of god dont drop the circlip.. it will vanish into thin air
^^^ +1 !!!!!!!!!!!!
yeah you can move it to the point where you can squeeze a screwdriver in there and prise it out, but sweet merciful fk don't drop it. i did and it landed on the plastic guard under the engine bay, the gf was not amused when i asked her to get it with her thinner arms, not amused at all haha
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
