Looks alot like a Normal HR31, But is that motor A carby RB30? or Maybe an Rb20e?
RB30S. We don't get any Skylines with a RB30E nor RB30ET. Just a High spec RB30S or low spec CA20S.
Hi Teng,
The engine cover looks like all our RB30 motors, i.e. single cam RB Motor (not a CA). All RB Engined cars in Australia (both GM Holden and Nissan) were EFI (i.e. RB30E). The only cars available directly from a Nissan dealer with a twin cam RB motor are the R32/33 GTR Skylines, with RB26DETT. There are many RB20DET and RB25DET cars in Australia, but they have all been imported as used cars from Japan.
The Interior shots look like a Series 1 R31 Skyline.
Almost all R31s in Australia had solid (live) rear axle. Only the HR31 (i.e. rare 2 door) had Independant Rear Suspension.
Cheers,
Daewoo
Sorry to hijack thread,
How come they chose to have live axle in Australia?
It seems quite odd seeing as my car (C210) and even the C110 all have IRS and R31 being newer should really continue that.
I searched all over and it seems Australia didn't have the coupe version (2-door). Even the GTS is a 4-door version. Why is that? I did find out that there are numerous trim levels from Japan and Australia versions. The RB30S is not sold in Japan and more like a export model which is why we can't get any information or parts from Japan. Even FAST doesn't work with any of the vins which has the RB30S Engines.
Over here we get the;
PJR31 CA20S 4-door
CR31 RB30S 4-door
KCR31 RB30S 2-door which is the one i have, as pictured above.
Edited by teng
I think its possibly due to a small market here for the R31 back in the day. They didn't sell as well as the VL commodore. Im pretty sure the top of the line model sold for about $30,000 back in the 80's which back then you could have bough a house for in some areas.
What exactly did you want to know about them?
Just information on the EFI system on the RB30E. Maybe doing a conversion next year and i will need to source alot of parts from Australia. The intake manifold from a VL is the same as that on the R31 so that's settled as i have one here at a local wreck about 100km from where i am lol but that' about it. Other things like injectors, ecu, full uncut wiring harness, sensors, afm, airbox and the lists go on. But i'm getting there slowly. lol
Thanks for most of your informations.
You can buy an R31 for almost nothing if all you want are parts... what we call wreckers, 'auto parts recyclers' will charge you a fortune if you buy bits and pieces, but you can buy a whole car for $Au500 easy... much easier than worrying about which parts from a Holden VL will fit a Nissan R31, when you can easily buy the whole Nissan R31 and get all the bits you need...
While it is true that the VL Commodore outsold the R31 Skyline by a lot, there are still plenty of Skylines about... Also, because Holden are shit, when they put the RB30 into the Comodore, they put the head lower than the top tank of the radiator... VLs always got air in the system and blew head gaskets while Skylines didn't... That is the Aussie Car Industry for you, can even take someone elses reliable engine and screw it up... so there are probably more Skylines on the road now than VLs...
Computer, Loom, Manifold(s), throttle linkages, Fuel Pump.
Often non-EFI cars don't have a return fuel line, so check your car...
I am sure this would be the easiest conversion you could do, and unless you are running multiple carburetors now, should give much better drivability and some horsepower gains...
Would it be difficult/expensive to import a whole cheap standard parts car into Brunei??? might not be worthwhile, (assuming you would pay a few thousand in shipping)... Otherwise, buy one on eBay in Western Australia, jump on a plane with your tools, drive it to the airport car park, strip it and leave it :lol:
Cheers,
Daewoo
Edited by Daewoo
Importing a car for parts is outta the question. The laws are quite strict here especially when i don't have an import licence and it's not easy to obtain one either.
When the time comes to salvage parts, i hope someone here at SAU will help me gather the bits and pieces that i need to convert it to EFI and turbo. I will need someone with access to both R31 and VL parts.
Will make a new thread when the time comes. Be sure to find a big box cause it will be filled up. lol
I didn't realise you were thinkng RB30ET...
If you were doing that, I would be thinking of going RB25DET or RB26DETT....
Yeah, well RB30ET will be unique here as there is no such engine here. Plus it will be on a KCR31 coupe.
Maybe easier to just buy and RB25 head and everything and convert your bottom end than find and RB30ET...
Not sure how difficult fitting the turbo manifold etc from a Holden to a Nissan would be..
Should be fairly easy, a lot of GQ patrol drivers throw away the carby and put the EFI manifold and turbo bits on for more power. Will most likely work the exact same way. You're going to get some serious squat in the rear end with all the torque.
I thought the Patrols were L30s, not RB30s...
and all Australia could muster was live axle even 10 years after the japs did IRS on the C210?
You would think Australia could do better than that.
Just a bit of information to add to this;
The government of the day (Bob Hawke) had no choice but to continue with the orders made by the Fraser government 1975~83 that any locally made & sold cars had to have a minimum local content so that they could get the imported parts & cars into Australia with tariff protection (Customs by-laws) and the chosen local diff supplier was Borg Warner and they didn't produce an IRS style diff & LSD's were something of expensive options.
Hence the Aussie R31 had a live BW rear axle, same as Ford & Holden of same era.
Mind you, there is only one Aussie Skyline, it's a bit of a pig except for the Gibson cars S1 & S2 GTS's compared to previous and later models.
Stick with an R30 & you can boast you own the original R34.
Cheers, D
I think my diff is open as well. Will need a LSD option fitted when my project starts. Hard to find one nowadays. Don't know if mine's 25 or 28 spline axle's. Maybe the Australian Silhouette version will fit. I heard it has 28 spline axles.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
