My one is for sale around that price, you can always make a offer the worst i can say is no :)
check out my link below
yeah looks mint but the kilometers on it is a bit to high, im planing to keep it for 6 years, so i want it with low kilometers. Sorry bro
Lol. Problem is, without a turbo, they're not good.
Yes true, im only buying it coz im ganna be on my p's, and then when im off my p's, im just ganna fix up the engine and chuck a massive turbo.
Hi mate, one of my mates is selling his 98 series 2 r33, manual, silver real mint. its also around the budget that your looking for.
http://firesport.com.au/1998-nissan-skylin...s--ad157026.htm
theres the link atm. hes not on sau and i dont have 10 posts to pm but yeh.
good luck.
May aswell get any skyline that works to drive on your p's then once you got your full licence and you still want a turbo car get the gts-t. Or by then maybe GT-T. Cant just throw a massive turbo in it. Theres other parts needed to thatll probably end up costing more than the gts-t. If your after a fast car for your p's and spending about 11k maybe take a look at a n/a supra if you like them. there almost as quick as a gts-t.
nah don't really want a supra coz my cousins got one, yeah might just buy a gts then when im full licensed i might as well buy a gtr, thats if i get a job lol
sorry about the link, but yeah as s4lva was saying too expensive to turbo a NA car better off selling it and getting a turbo skyline later, thats what i'm doing =D
BTW this link should work
http://www.skylinesaustralia.com/forums/R3...&hl=r33+gts
mine does have pretty high km's but is well below your budget of 11K, you could easily put a low km RB25DE in it and you'll still have cash left.
Edited by 2FST4U.R33
Yeh its just your first car. Non turbo, just something to get around in really. Once your off your p's then you should buy a car youll want to spend money on. Youll get the urge to spend all your cash on your first car, Rims sound system exhaust etc but most of us end up regretting spending too much on our first cars and wishing we could have it back for our next one :P But it'll be your car and all upto you what you do with it. But you got the right idea getting the gtr after ;) Im still looking for my skyline, theres not many in good condition for sale :D
I've price dropped mine to 11k ono because of the high ish KM (keep in mind most around 100,000km havnt had timing belt changed and a full service which will cost around $1000)
Do what I'm doing buy a non turbo and then a GTR which is why im selling :P
Do what I'm doing buy a non turbo and then a GTR which is why im selling ;)
yeahh i might do that as well, man your car is hot, but ill think about it, thanks a lot broo :P
Hey mate,
Dunno if you are still looking for one but ive got one for $7,000 with 12 months rego.
http://www.skylinesaustralia.com/forums/Tu...12-t326528.html
Cheers,
Chris
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
