Hi All,
Im Building a 25/30, just a couple of questions.
Im not THAT familiar with rb25 heads.
I have most of the parts togeather and done research into it,
The parts i have are,
- RB25DET Head (Reco'd, Ported, Polished, Heavier Springs)
- Std cams
- Greddy Plenum
- Hi mount manifold
- HKS waste gate
- Garrett GT3540/GT35r
- Std Loom
- GTR Rail
- Denso Injectors (800 or 880cc i cant recall)
- Apexi Power FC
- Rocker Covers
- Cam Gears
- Cam Buckels/Holders (Not sure exact name for them, the thing that hold the cams to the head)
- CAS
- Lifters
- Cam Cover
- Oil Restrictor
- RB30DET Timing Belt
- SplitFire Coil Packs
- CAS
- Ingnition Box
So Wat EXACTLY do i still need? Please BE fussy and specific.
Also what do i need exactly for the plenum as in air vaules and sensors for the greddy plenum?
any thing i dont need on the electric side of things when using Power FC?
What else do i need for the conversion other then mods for timing tensioner, and welding the oil gallery?
I know i still need:
- Oil & Water Lines
- Dump Pipe
- WasteGate Pipe
- Throttle Body
- ARP Head Studs
- Gasket/Seal Kit for Head
Anyone know where i can get some of the parts from?
Mainly Need to know what i need is need to the greddy plenum, i have NO electrics for the head or plenum and not sure what is needed as i dont have a standard plenum to get parts or see what parts it has. Only really worked on RB30's.
Thanks you all.
i find starting with a r31 and a rb25/30 engine works the best
what else... maybe some tyres and rego so you can enjoy it
Haha Yes im hoping to enjoy it, cars rego'd n has tyres just need some for things for the head thats all.
Any one able to help me out?
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
