I know you have said it was aligned twice but was this done by a laser or by string line?
Last time it was done by Road and Race performance of Rydalmere.
Im still thinking it may be the 15mm spring height difference?
So what would be the best springs to use to replace.
  • Replies 46
Dom is that the same silver item you took me for a wrap in some months ago? (came to buy helmets etc I was the wog).
Perhaps its karma, all those half nekid pics of u in bed with wads of cash LOL
15mm lower on one corner???!!!!! and yet you are asking about wheel alignment etc?? How if this car is on standard suspension is one corner 15mm lower, further to that what does the VDC etc think is going on when it is already seeing Gs going back and left?? DMS is good, MCA is BETTER. used both on rally cars. Suspension setup and tuning effects a car so much more than you will ever believe. My RS Impreza rally car, with DMS was unreal on one setting, but I felt it could go softer, we took 2 clicks (of 20) out of it, spent the next 2 stages chasing the front on hard pack, then the road would turn muddy and I could not make it go straight, back one click, and heaven!!!
agree. everyone is talking about all sorts of variables but I cant get over the drop on the rear passenger corner, something major wrong there. I wouldn't be investigating wheel or tyre setup until the suspension has been thoroughly inspected. sounds like you are a serious driver so might as well look at a full coilover setup while your at it. Lots of people have gone for JRZ and have had very good results. I have used MCA. good first up results even with suspension being only crudely setup for my first track day on it, much work with tuning to come.
Why keep experimenting and spending the money over and over?
Just take it to Col Crawford Nissan Performance Centre at Brookvale. They are a GT-R dealer, properly
trained and equipped to fix your car and align it to factory street or race specs on a fantastic fully interactive alignment machine
(the only other one like it I saw doing my other car at Marshalls Mercedes in Parramatta, but there may be others out there)
Ask Matt or Steve for advice and they will check your total suspension for any faults.
Before you throw out the factory set up check first what's wrong with it.
BTW, you should be able to go through Turn 1 at EC at 180kph in a stock car, with stock Bridgestones, set on 3 x R with street spec camber, lap after lap, without going sideways and getting a heart attack ! ;)
At this stage I may drop the car into DMS and get them to build a set of coilovers and springs to suit the car being a rally car.
Fair price and much closer.
The car is a JDM unregistered stripped out race car with cage.
Id love to take it to a Nissan dealer but they are so hard up they wont even sell you an oil filter if you have a JDM, lucky the GTR uses the same oil filter as a Ford Telstar/Mazda 626.
Edited by Dominic
that is a good way to go for what you want. but personally I'd try and sort your problem before changing stuff. as you'd hate to carry it over to a new set-up. there is something fundamentally wrong for it to be handling as evil as you say it is.
My concern is there may be a VDC issue causing it rather than springs and wheel alignment, neither of which GTR is 'particularly' sensitive to from a stance viewpoint
But if its sideways everywhere then its pretty much in 2WD.....Regardless we can fix :P
Edited by Martin Donnon
Now I have a bit more time I can advise you of the correct process Dominic.
A normal power run for your car should give you a Torque Split front/rear curve that stays at around 50% the whole way through the run, possibly heading towards a rear split of 60% towards the end. If there is a massive variance in this then you will have a VDC issue. The very first thing to do is read, note, and then clear the codes with your Cobb Accessport. If this does not fix the issue then you potentially have a transmission issue with the front output shaft assy of the GKN magnetic clutch.
I'll say it again, 15mm of negative wedge (which is what you've got with the left rear being 15mmm lower) is HUGE and is going to cause the car to be very loose in left hand turns (T1 at EC). By all means keep looking for driveline problems, but don't overlook the most basic setup problem your car has.
  • 7 months later...
    • He obviously had his reason for flipping you off. I wonder what it was...
    • Thats why I stay far, far away from Eastwood. only go there if I wanna eat Korean food
    • I have to agree like, yesterday, I was driving down the warringah freeway towards the bridge when this jackass driving a beaten up Honda civic cut me off so suddenly it made me almost yank the wheel to avoid him hitting my car. Honestly and he had the NERVE to flip me off (or some other gesture Idk). Im a calm guy, but really some people just dont deserve to have a license, let alone be allowed to drive on densely populated roads/highways. If youre gonna cut through lanes at least use the damn turn signal
    • HPA do an interesting video on tuning, and Adrian shows on the dyno, moving from 10:1 to 12:1 (And I think even 13:1) and the power moves SFA. However, a couple of degrees of timing has a HUGE impact. Exhaust side of things will more be the length of the exhaust and how many bends and turns you have. The straighter you can keep it, the better. By a lot. Oh, and getting the diameter right. Bigger isn't always better. Going to big can actually lose you power.
    • I have to say, most people I see on the road fit the bill of atrocious drivers. Whether they be cowboys in their dual cabs, bogans in the Commodores, or the soccer mums. Pretty much most people on the road put zero freaking thought into driving. Barely look further up the road then the end of their bonnet, and have never even thought about how catastrophically wrong shit can go, by doing what they all deem as normal driving. Especially their late braking, racing to stopped lights, and sitting half a foot off the bumper of the car in front at 110km/h. Wanna know what's even better? By the time their kids get to be old enough to learn to drive, they've already got in the back of their brain what is normal driving, how annoyed you're allowed to get at people etc, and then their parents who actually have zero freaking skill at driving (Even though they constantly say "I've been driving for 20 years and never had an accident!") teach the little twerps how to drive, or should I say, how to make a car move. Literally watched a parent teach their L Plater, on a 4 lane freeway, that you just slam the brakes on, and push your way over, even with a B Double bearing down on you, and that's how you should drive, rather then, just keep going to the next exit. Same shit happens all the time for side streets etc, watching numpties pull dumb shit turns pushing across 3 lanes of traffic, rather than just go up the road another 30 seconds, and take the next turn that'll get you to the same location... Oh, and the damn right lane bandits. Or the retards driving along with their headphones in, and can't hear the ambulance or fire truck right up their ass about to run them over...   Pretty much, people drive on the road, like ego centric f**ks, and don't actually think how dumb shit their driving is, how it could easily kill them or someone else in a split second, or at the very least, how they're driving is contributing to all the shit they're bitching about on the road, like shitty congestion!
