hey guys just bought myself a cheap r32 to get back into drifting with
have been an sr20/silvia man up till now so know little about whats the best way to go about modding a rb20det, however im guessing the basics are much the same to an sr
not looking to spend much $ at all
all the car has atm is a fmic and zaust and boost tap currently running standered boost atm.
ok so question #1 - are stock r32 fuel pumps as shit as stock silvia fuel pumps, aka soon as u wind up the boost they lack pumping power, how much rwkw can the stockers hold?
#2 2nd hand r33 turbos are cheap as chips, is it worth bolting one on over the standard 32 turbo?
#3 without a after market ecu/tune what is the max but safest boost level to run? assuming i have a r33 turbo on the car
#4 are there any cheap piggy back/ ecu retunes that are popular with rb's
#5 with a tune and r33 turbo whats the likly rwkw i will see? is 180 possible? if so at what kw do the standard injectors need replacing
thanks heaps looking forward to your responses :P
https://www.sau.com.au/forums/topic/326726-r32-performace-help-rb-engine-noob/
1. Yes. How long is a piece of string? put a decent (read: Bosch minimum) fuel pump in.
2. Yes. Good bang for buck. Untuned, I got an extra 50rwhp and more fun in the top end.
3. Wind it up until it pings. With the stock RB20 turbo my engine handled 14psi and made ~200rwhp. With the RB25 turbo is would only take 12psi (14psi and she pinged) but made ~250rwhp.
4. Plenty, but better off saving up and Nistuning it.
5. 180rwkw with a tune is easy, mine was mkaing 183ish (~250rwhp) without a tune. Stock injectors should be good for almost 200rwkw.
Edited by bubba
I still have the stock on mine and its going fine at 140rwkw but for peace of mind and at only a few hundred buckes go the 040.
#2 Yep do it, if you can get the 45v2 (the series 2 turbo)
#3 after putting my rb25 turbo on i have 13:1 (dangeresly lean) AFR untill 5000 rpm were it fuel dumps and the AFR become 11.5: (what you wont the whole time) also i gained 2 rwkw (rb20 turbo at 14psi) with the boost set at 5psi.
#4 go with nistune ist about $480 plus tune.
#5 im hopeing for 160-170 rwkw at 12psi.
Edited by redliningr31 skyline
No they won't, not without fuel pressure bumped up.
3 Possible reasons
1: Dyno readin fudged
2: You Don't have stock injectors(higflowed or a/m)
3: Fuel Pressure Bumped up
1: highly doubt it, reputable tuner here in Perth that I have used a fair bit and he wasn't trying to sell me anything
2: they were completely stock.
3: stock fpr.
Srsly guys, it is NOT a clear cut THIS IS WHEN YOU WILL MAX SOMETHING OUT.
Tell me, who has maxed a stock afm? and the circumstances?
RB20DET, stock afm, stock injectors, stock ecu, 12psi through RB25 turbo, 183rwkw - AFM NOT MAXED
I then went RB30DET, stock afm, stock injectors, stock ecu, 12psi through RB25 turbo, 183rwkw (a lot sooner) - AFM MAXED AT ~6000rpm
But anyway, a dyno is NOT a COMPARISON tool unless you are all using the SAME dyno on the SAME day with the SAME parameters.
If you are going to argue with me about 20hp, then you're a dickhead.
Edited by bubba
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
