Andrew,
A good mate of mine up your way (his nick is 'third' on SAU) has been researching this exact topic recently! He has a '97 GT-R with a quite a few mods (311awkw SAS dyno) & at times runs 20+psi.
As you can imagine he's had a wide range of responses on the stock BOV topic. Jim from CRD seemed to think the stock BOV's weren't a problem even at mid 300kw levels (at wheels). We asked a few local Adelaide tuners & one of them said straight away that above 15psi & they "can" leak.
He is planning on doing a bench level pressure test to see exactly what psi his BOV's open, may have already done it?
No prob's mate. It 'may' take a little while for him to reply as he's not a frequent SAU user (posted twice in total) Tell you what, I'll give him a ring tonight & see what he's got to say.
Do they leak easily?
I'll be running upto 1.5  bar... Will the stock BOVs be okay? Or will they be leaking causing me to stress the turbos out unnecessarily to make 1.5 bar at the plenum?
Theyre crap, want to sell them to me or trade for Blitz DD setup? :):D
Being serious though, ive been told by many a shop they can hold decent amounts of boost without leaking (upwards of 1 bar). If you do take them off, send me a PM as ill be extremely interested in buying them. The Blitz ones are cool and all, but nothing compares to the woosh noise the stock ones make.
Hey, thanks heaps for the help guys!
Amaru: I'll probably end up replacing them with a single Trust Type-R BOV in a few months time... If I do, I'll send you a PM...
YRL05S: That would be great, but does your compressor have variable psi? If not, how will you know what pressure it takes before they open? Let me know how you go :)
  • 2 months later...
Merli,
I have used Blitz ones and they make the car run terrible. Boost isnt responsive and idle is horrible. On recommendation from HKS Japan, I have returned to the standard GTR ones. Even HKS do not recommend replacing the bov. Even if using a hks item.
Quote: "BOV changea.. noo good.." "Original good"
FYI: this was for a gtr running 2530's.
Whoa... this is an old thread! :D
Butthead: I'm not going back to stock BOVs, I have them on there at the moment, and I was worried that they would open prematurely and leak, causing my turbos to spin extra hard to make the 1.5-1.6 bar I want at the plenum... So I started this thread to see if I would need to change to a Trust Type-R or something like that... Seems like the stockies will work just fine!
Thanks N/A... Sounds like the stock bovs are going to stay! :(
Kamikaze: Not sure whether they're spring or diaphragm-type bovs... In fact I don't even know if there's a difference :)
Guest INASNT
we should ask leewah how they are as he still uses them on the 500rwkw plus gtr
the ice supra which has 400+rwkws runs these aswell aparently
niges supra is putting down 500rwkw with 2 bar boost now and still using stock GTR bovs just like Leewah, so i guess they aint that bad.
I got some in my car now as well and its holding 19psi and 280rwkw easily
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
