On 11/09/2016 at 0:52 PM, R377 said:
bit of stretch and camber.
9.5/10.5 +22  225/35 and 245/35 19
Actually the owner tells me this is actually standard camber.  Wheels are ESR Wheels SR08
http://esrwheels.com.au/product/sr08/
  • 3 months later...
  • 1 month later...
  • 4 weeks later...
  • 2 months later...
  • 5 years later...
