Hey everyone,
i was just doing some searching on whether i could replace my stock GTR afms for some green label RB20/25 ones.
i have read some posts saying that it is possible, but i was wondering whether there is anyone that is using 2 green label AFM's on their GTR and what issues they experienced with it. for me it seems to be the much cheaper option than forking out for a pair of z32's. i am not chasing huge power.
my mods are
2860-5's
Nistune ECU
660cc injectors
Walbro fuel pump
3in exhaust with a 3.5in muffler
3in highflow cat
rebuild engine with forged internals
recond head done while engine out for rebuild
stock r34 GTR intercooler
stock AFM's
i had it last dynoed and got 320rwkw @ 18psi
i know that the turbos have much more room for more power. but i would be limited to the stock intercooler and 3in exhaust
but i would like to just be able to bump the boost up to 20psi and see if i could get close to 350rwkw without maxing out my AFM's
so to me paying $400 for a second hand set of z32's and getting some piping and filters for the bigger AFM's is not worth the extra 30rwkw. so if i could pick up some green label AFM's for cheaper i would be much happier, and my wallet would be a little fuller.
Cheers,
https://www.sau.com.au/forums/topic/326962-rb25-afms-on-a-gtr/
It is doable, you will require a retune just as if you had installed Z32s or nismo AFMs.
Guaranteed it is covered more than enough on the forum, it would be almost the exact same deal as installing Z32s. You will need a new suction pipe to fit the 80mm AFMs as the stocks are 65mm and you will need the plugs for them also.
AFAIK you will also need to change your air filters.
Thats EVERYTHING you need to know.
Hey everyone,
my mods are
2860-5's
Nistune ECU
660cc injectors
Walbro fuel pump
3in highflow cat
stock AFM's
Cheers,
$400 for 30Kw is a very good deal, once you do all the basic stuff like ECU and Exhaust, getting a whack of power like that get's a whole lot more expensive then $400...
My 2c :D
Pluses I found for using 2 RB25 AFM's- they fit on the stock inlet piping (with a little stretching, and I needed to add an elbow to get the top one around the power steering res) and they plug straight into the standard plugs.
Well there you go!
Although, they are the same size as a Z32 and have been said NOT to fit.
cheer's guys,
i am aware that i'll need to get a retune for the bigger AFM's, that's not an issue. i'll speak to my tuner and ask whether he is able to do it.
another tuner i spoke to about this told me he wouldnt do it, because he wont tune on second hand AFM's he only uses brand new z32's because he said that its very hard to get the tune right on GTR's because there are 2 AFM's and they could be reading differently?
all i am after is a little more scope so with a slight bit more boost i have some reading from the AFM's that isnt at full.
will post back once i get it done with the results
cheer's guys,
If thats the case, just get nismo or mines afm's, direct fit and same power handling as they are essentially std units recalibrated to near z32 specs. The smaller body of the nismo /mines items allow nicer low and mid tuning.
Well there you go!
And yes you need to change your air filter setup as the afm's (either ones) are physically bigger. The inlet pipes are quite stretchy, will stretch to accomadate 3'' piping. Keeping the same plug for the rb25's was the factor that decided it for me at the time. If I was going to keep running afm's (I now run motec) I would seriously consider the nismo option though expensive, they are brand new, have the required resolution for the sort of power you're after with a streetable twin turbo setup and fit without modification (apart from tuning of course).
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
